New Angular Velocity of Star with Diameter Shrink to 0.17 Times
  • Thread starter Thread starter Naldo6
    Angular
The discussion revolves around a physics problem concerning the angular velocity of a star whose diameter is reduced to 0.17 times its original size. The problem involves concepts of conservation laws and uniform mass distribution.
  • Exploratory, Assumption checking
  • Participants are attempting to identify conserved quantities relevant to the problem, such as angular momentum. Questions about how to begin the exercise and the implications of the diameter change are raised.
Some participants have expressed uncertainty about how to approach the problem, while others have suggested focusing on conservation principles to guide the solution process. There is no explicit consensus on the next steps, but a productive direction has been indicated through the discussion of conservation laws.
Participants are reminded of forum rules that prohibit providing complete solutions, emphasizing the importance of understanding the underlying principles instead.
Naldo6
The mass of a star is 1.1e31 kg and its angular velocity is 1.40×10-7 rad/s. Find its new angular velocity if the diameter suddenly shrinks to 0.17 times its present size. Assume a uniform mass distribution before and after. [Icm for a solid sphere of uniform density is 2/5 mr^2].
Can anyone helps me please?... i don't know hoyw to begin this exercise...
Hi Naldo6,
What quantity would be conserved in this process?
can u solve me this problem?...
I'm sorry Naldo, but forum rules here prohibit doing someone else's homework for them. If I were to just solve the problem for you the multitude of homework helpers and mentors would unite and rise against me and crush me like a worm.
So instead of that, think of what quantity would be conserved here. There should only be a few conserved quantities that you have studied: energy, momentum, etc. What other conservation equation have you studied, that applies here? Once you have determined that, you can use that to write an equation that will help you solve the problem.
18K
  • · Replies 40 ·
