Continuity on Restrictions Implies Continuity Everywhere
  • Thread starter Thread starter e(ho0n3
    Continuity
The problem involves proving the continuity of a function defined on the union of two closed subsets of a metric space, given that it is continuous on each subset. The context is within the study of metric spaces and continuity in topology.
  • Mixed
  • The original poster attempts multiple approaches, including examining the closedness of inverse images and using contradiction. Participants discuss the implications of continuity on subsets and the properties of closed sets in different topologies.
Participants are exploring various interpretations of the problem, with some providing insights on the properties of closed sets and continuity. There is an ongoing dialogue about the implications of these properties, but no consensus has been reached on a definitive approach.
Participants note potential circular reasoning in the original poster's argument and discuss the nuances of closed sets in different topological contexts. The discussion includes considerations of how closedness behaves under restrictions and unions.
e(ho0n3
Let (E, m) and (E', m') be metric spaces, let A and B be closed subsets of E such that their union equals E, and let f be a function from E into E'. Prove that if f is continuous on A and on B, then f is continuous on E.
The attempt at a solution
I have approached this problem in three ways, but in each I get stuck.
First approach: Let S' be a closed subset of E' and let S = f-1(S'). If I can demonstrate the S is closed, then f is continuous on E. I wrote S as [tex](S \cap A) \cup (S \cap B)[/tex] and attempted to demonstrate that each intersection is closed. However, each intersection is closed if S is closed. This is a circular argument so it won't work. What else can I do here?
Second approach: Let p belong to E and let e > 0. Then either p belongs to A or p belongs to B. If the former, then there is a d(A) > 0 such that m'(f(p), f(q)) < e for all q in A satisfying m(p, q) < d(A). Now suppose there is a s in E such that m(p, s) < d(A) but m'(f(p), f(s)) ≥ e. This s must be in B. Since f is continuous on B, there is a d(B) > 0 such that m'(f(s), f(q)) < e for all in B satisfying m(s, q) < d(B). I don't know how to proceed from here.
Third approach: Suppose by way of contradiction that f is not continuous on E. Then for some p in E, for some e > 0, for all d > 0, there is a q in E such m(p, q) < d but m'(f(p), f(q)) ≥ e. I stopped here when I realized this is proceeding similarly as the second approach.
I don't see anything circular about your first approach. The inverse image of each closed subset is closed. The union is f^(-1)(S'). The union of two closed sets is closed. Hence f^(-1)(S') is closed if S' is closed. Sounds pretty airtight to me.
That only works if f is continuous in E, which is what I'm trying to prove.
The intersection of S and A is closed if both S and A are closed. I already know that A is closed. That means I must only worry about S, but that's what I was worrying about from the beginning. In other words: S is closed iff the intersection of S and A (and S and B) is closed iff S is closed. This is the circular argument I'm referring to.
But S=f^(-1)(S')=(f|A)^(-1)(S') union (f|B)^(-1)(S') where f|A and f|B are the restrictions. (f|A)^(-1)(S') is a closed subset of A (technically, 'in the topology of E restricted to A') since it's continuous ON A. There is a little bit to worry about here. For example, if O is an open set in E, a closed subset of O is not necessarily a closed subset of E. Take the example of E=R (reals), O=(-1,1), and A=[0,1). A is closed in O. But A is not closed in R. Do you see what I mean? But a closed subset of a closed set is closed.
This never occurred to me. Jeez...
Right.
Yes. A may be written as the intersection of O with [0,1], which is closed in R, hence A is closed in O.
You mean: if A is closed in B and B is closed in E, then A is closed in E? In other words, "closedness" is transitive?
Right.
Yes, exactly. "closedness" is transitive. It's easy to prove.
Maybe for you but no for me: Let A', B' be the complements of A, B in E. Then B' is a subset of A' since A is a subset of B. Pick a p in A'. If p is in B', then we can find an open ball centered at p entirely contained in B' and consequently in A'. But what if p is not in B', i.e. what if p is in B?
Ok, pick a p not in A. Either p is in B-A, in which case there is a ball around it that doesn't touch A because A IS CLOSED IN B. Or p is in E-B which means there is a ball around it that doesn't touch B because B IS CLOSED IN E. In the second case you also know the ball doesn't touch A because A is contained in B.
Neat. Thank you for the perspicuous explanation.
  • · Replies 18 ·
