Can the Integral of e^(ax) - e^(bx) be Simplified?
  • Context: Graduate
  • Thread starter Thread starter eof
    Integral
The discussion revolves around the integral of the expression \(\int_0^\infty \frac{e^{ax}-e^{bx}}{(1+e^{ax})(1+e^{bx})}\). Participants explore methods for simplifying this integral, including partial fraction decomposition and potential shortcuts, while considering convergence conditions.
  • Exploratory, Technical explanation, Debate/contested, Homework-related
  • One participant outlines a method involving partial fractions to simplify the integral, suggesting that it can be calculated in a straightforward but messy manner.
  • Another participant expresses skepticism about the existence of a quicker method for solving the integral.
  • A third participant notes that additional conditions were provided to ensure convergence but struggles to identify useful assumptions.
  • One participant proposes an alternative approach to the first partial fraction separation, suggesting a quicker method by manipulating the numerator.
  • Another participant questions the feasibility of completing the integral in under two minutes, indicating that it seems challenging.
Participants do not reach a consensus on the existence of a simpler method for solving the integral, and there are differing opinions on the feasibility of completing the calculation quickly.
Participants mention additional conditions for convergence, but these conditions are not specified, leaving some assumptions unresolved.
eof
Hi,
I friend of mine gave me the following integral to calculate:
[tex]\int_0^\infty \frac{e^{ax}-e^{bx}}{(1+e^{ax})(1+e^{bx})}[/tex]
This can de done by first doing partial fractions which gives you
[tex]\int_0^\infty \frac{1}{1+e^{bx}}-\frac{1}{1+e^{ax}}[/tex]
then we can calculate each one by substituting [tex]t=1+e^{ax}[/tex] (and similarly for the other term). Hence
[tex]dx=\frac{dt}{a(t-1)}[/tex],
and finally after doing partial fraction again after the substitution, it boils down to
[tex] \frac{(a-b)\ln 2}{ab}+\lim_{x\rightarrow\infty}\ln\frac{(1+e^{ax})^b}{(1+e^{bx})^a}<br /> =\frac{(a-b)\ln 2}{ab}[/tex]
where the second term disappears. The calculation is straightforward, though quite messy. This had been on an actuarial exam a few years ago where they were actually expecting you to calculate it in under 2 minutes.
I've been trying to figure out if there is an "easier" way to see the answer, but haven't come up with anything useful. I can't convert it into any known integral from Fourier analysis or see how to apply the calculus of residues or something similar. Any ideas?
There's no particulr reason for why there should exist a quicker way of doing this
Yeah, I've been thinking about the same thing and that is puzzling me. :)
EDIT: There were some extra conditions given (to ensure that it really converges), but I can't come up with an assumption that would do any good either.
For the first partial fraction separation, you don't actually need to the full partial fractions alculation. Notice that you can add 0 = 1 -1 to the numerator, which gives you (1 + e^(ax)) - (1 + e^(bx)), so you can split it up within seconds to get to your second line.
For the second partial fraction expansion, you can probably just look at it and guess what the coefficients need to be instead of working them out. You have A/t + B/(t-1), so looking at that, A = -1, B = 1 should do the job, as you can check pretty quickly.
If you cut corners like that instead of doing the full calculation of the partial fraction separation, it should really cut down on the time taken to do that integral.
How do you know it was under 2 minutes? That seems a bit difficult.
  • · Replies 27 ·
  • · Replies 19 ·
  • · Replies 17 ·
