The air drag and magnus pass spin axis?
The discussion revolves around the effects of air drag and Magnus forces on a spinning ball, specifically focusing on the relationship between these forces and the spin axis. Participants explore the implications of these forces in the context of sports like baseball and table tennis, examining how they influence the ball's trajectory and rotation over time.
  • Some participants inquire whether the air drag and Magnus forces pass through the spin axis of the ball, suggesting that there is an uneven distribution of forces acting on the ball.
  • It is proposed that the forces can be decomposed into a couple with torque about the y-axis and an unbalanced force that includes lift and drag.
  • Questions are raised about whether the spin axis remains parallel to the y-axis over time, particularly under different orientations of the spin axis relative to the ground and the ball's velocity.
  • One participant suggests that if the spin axis is perpendicular to the ground, it may vary over time, while another believes that in a typical pitch, the axis would not change significantly.
  • There is a mention of detecting the spin ratio of a flying table tennis ball and the complications that arise if the spin axis changes direction during its trajectory.
  • Some participants note the dynamic forces on the ball are significant compared to its moment of inertia, indicating a complex interaction between forces.
  • Suggestions are made for further exploration of the topic in a different forum section, particularly regarding aeronautical engineering perspectives.
Participants express varying views on the behavior of the spin axis and the effects of forces acting on the ball. There is no clear consensus on how these forces interact or the extent to which the spin axis may change over time.
Participants acknowledge that the discussion involves assumptions about the forces acting on the ball and their distribution, which may depend on specific conditions such as the angle of the spin axis and the nature of the throw.
This discussion may be of interest to those studying fluid dynamics, sports physics, or anyone curious about the mechanics of spinning objects in motion.
zyh
The air drag and magnus pass through spin axis?
A ball is flying in the air, and it has spin on y axis, show below.
F1 is the air drag force.
F2 is the magnus force.
My question is: the air drag and the magnus force is pass through the spin axis? Or, the ball will change the torque direction. Thanks.
zyh said:
My question is: the air drag and the magnus force is pass the spin axis? Or, the ball will change the torque direction. Thanks.
Are you asking if these forces are passing through the spin axis?
There will be an unevenly distribution of forces acting on the surface of the ball in the xz-plane. Together, these can be decomposed into a force couple with torque about the y-axis, in addition to an unbalanced force. The unbalanced force is both lift and drag.
In general, the unbalanced force would not act through the center of the ball.
It's kind of a no brainer that the viscous drag forces will show the rotation. This would leave the lift and induced drag to consider.
Yes, Thanks Phrak for your hint, I have changed the original post.
BTW, I'm not an English native speaker, so, I'd try to improve my written English ability.^_^
Read it again. I've been editing. We've each been writing to moving targets. :smile:
Did you mean that the distribution of forces can decomposed to two parts?
One force is couple with torque about the y axis, which will slow down the rotation?
The other force is " lift and drag", which will slow down the motion and get a curve track.
Another question is : After a period of time, the spin axis will still be parallel to the y axis?
Thanks.
That's about it, yes. The lift can also act against the force of gravity if you include it.
http://emweb.unl.edu/negahban/em223/note8/note8.htm
Thanks.
If all the initial forces: lift, drag, mg, and the force couple act in the same plane, the spin axis won't process. This would be the case with the spin axis horizontal to the ground.
thanks
I read the web page your suggest: Equivalent force systems.
I do agree with you that there are three force:
gravity, lift, and drag.
and there is a couple
I think it is right, because there is no reason that every
But if the spin axis is perpendicular to the ground, and is perpendicular to the Velocity of the ball( see my picture, the Y axis is the spin axis, and the Z-X plane is the ground plane). In this case, the spin axis will vary during several time?
We're talking baseball, right? I don't think, in a pitch, the axis will change more than a couple degrees in a normal throw. If the initial spin is slow enough, it may be significant. I dunno.
I mentioned table tennis which is the same as baseball I think. I'm trying to detect a spin ratio of the flying table tennis ball through it's trajectory. If the spin axis doesn't change it's direct, it may work, otherwise, it will be more complicated.
Well, that gets interesting. The dynamic forces on the ball are large compared to its moment of inertial. But this takes the problem outside of my scope.
A wiffle ball ping pong ball could get real intesting. Poke some holes in one and see what happens.
...It occurs to me that the aeronautical engineers around here could be more helpful. In this folder:
https://www.physicsforums.com/forumdisplay.php?f=187
Thanks for your suggestion.
I'd prepare a new post there.
  • · Replies 25 ·
  • · Replies 23 ·
