Calculating decay constants and half-life
The discussion revolves around calculating the decay constant and half-life of radioactive potassium in a rock sample. The original poster presents measurements related to the decay rate and mass of potassium and argon, along with relevant equations for determining the decay constant.
  • The original poster attempts to calculate the number of potassium atoms and the decay constant using the provided measurements and equations. Some participants question the accuracy of constants used, such as Avogadro's Constant, while others suggest checking calculations for potential errors.
The discussion has seen various attempts to arrive at the correct decay constant, with some participants expressing confusion over their calculations. Guidance has been offered regarding the method, and there is acknowledgment of potential calculator errors. The conversation reflects a mix of exploration and verification of mathematical reasoning.
Participants are working under the constraints of homework rules, which may limit the extent of guidance provided. There is an ongoing exploration of assumptions related to the values used in calculations.
Steph191290
A scientist wishes to find the age of a sample of rock. Realising that it contains radioactive potassium, which decays to give a stable form of argon, the scientist started by making the following measurments:
decay rate of the potassium in the sample = 0.16Bq
mass of potassium in the sample = 0.6x10^-6g
mass of argon in the sample = 4.2x10^-6g
The Molar mass of the potassium is 40g. show that the decay constant for potassium is 1.8x10-17 and its half-life is 1.2x10^9years.
decay constant = a/N
n=m/Mr
N=m/Mr
N=0.6x10^-6/40
N=1.5x10^-8
N=1.5x10^-8 x 6.02x10^-8
N=9.03 x 10^-16
decay constant = 0.16/9.03x10^-16
I got this far then got stck as the answer was wrong, I am not sure wher to go from here any help would be appreciated.
You might want to check the value of Avogadro's Constant :wink:
oops that should have been 10^23 lol, thanks i'll try that
x
now i get 1.4448x10^15 which is still wrong, I am so confused.
x
x
Your method is correct, you must just be punching the numbers into your calculator wrong. How many K atoms did you calculate?
9.03x10^15
x
Steph191290 said:
9.03x10^15
x
Looks right to me.
well i don't know what i did but i have just gotten the right answer thanks lol
xx
xx
As I said above, your method was spot on but you were probably just hitting the wrong buttons on your calculator.
thanks lol, i do that a lot it seems, better brush up on those skills before the exam lol.
