New Reply
Fluid Mechanic help- Find the acceleration rate of a pipe that decreases in diameter
Share Thread Thread Tools
Oct26-08, 11:36 AM   #1
A pipe is designed to have its cross sectional area decreasing linearly from 12-inch diameter to 6-inch diameter. What is the acceleration rate at a section 10 inches from the ending section of 12-inch pipe at time = 3 sec? The volume flow rate Q=2t cfs (note: t is in sec). Also given is the length of pipe from the 12-inch diameter to the 6-inch diameter is 30-inches.
2. Relevant equations
Might use ax = du/dt
3. The attempt at a solution
Tried solving Q by letting t=3 and substituting into the Q equation to get 6 cfs, but it hasn't led me any where.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Jul23-11, 07:31 PM   #2
I have a similar question in my Fluid Mechanics book.
Diameter of duct changes linearly over a length of 3m, being 0.46m at entry and 0.15m at outlet. If flow is steady and volume rate of flow is 0.3m^3/s, determine rate of acceleration of fluid at a point halfway along duct.
Determine total rate of acceleration at same point if volume rate of flow increases at 0.37m^3/s^2.
How do you calculate this?
New Reply
Thread Tools
Similar Threads for: Fluid Mechanic help- Find the acceleration rate of a pipe that decreases in diameter
Thread Forum Replies
mechanic fluid Introductory Physics Homework 6
Fluid Mechanic Introductory Physics Homework 2
Fluid mechanic, Total pressure Classical Physics 18
Flow through a pipe along a reduced diameter General Engineering 1
f frequency of small diameter organ pipe Introductory Physics Homework 5
