Reactions And bending moment and shear force diagrams
This discussion focuses on calculating support reactions for uniformly distributed loads (UDLs) and their representation in bending moment and shear force diagrams. For triangularly distributed loads, replace the load with a single force at the centroid to determine magnitude and placement. The slope of the shear diagram corresponds to the negative value of the distributed load, while the moment diagram's slope reflects the shear value. Maximum bending moments occur at points of zero shear, and inflection points arise at zero moment locations.
  • Understanding of support reactions in structural analysis
  • Knowledge of uniformly distributed loads (UDLs) and their characteristics
  • Familiarity with bending moment and shear force diagrams
  • Concept of centroids and their application in load calculations
  • Study the calculation of support reactions for triangularly distributed loads
  • Learn how to construct bending moment and shear force diagrams
  • Research methods for identifying maximum bending moments and points of inflection
  • Explore the effects of varying load types on structural analysis
Civil engineers, structural analysts, and students studying mechanics of materials will benefit from this discussion, particularly those focusing on load analysis and structural design principles.
Stacyg
Hi.
I've been given this to calculate the support reactions but I'm not sure how to handle the increasing udl. And how would this be shown on a Bending moment and shear force diagram??
Also with non increasing Udl's when calculating the reaction is it best to change the udl to one force mid-span of the udl or two forces one at each end of the udl??
And how do you calculate maximum bending moment and points of inflection ?
Thanks
Stacyg said:
Hi.
In calculating support reactions from a triangularly distributed laod, replace the distributed load with a single force acting at the center of gravity (centroid) of the triangle. What would be the magnitude of that force, and where would it be placed?
The slope of the shear diagram at a given point is equal to the negative value of the distributed load at that point. The slope of the moment diagram at a given point is equal to the shear value at that point.
either way will work, but why use two forces when one will do?
in the absence of 'point' moments or couples, maximum moments occur at the point of zero shear. Inflection points , if they exist, occur at the points of zero moment.
