Solving Homogeneous System of n Linear Equations with Positive Integer k
The discussion revolves around a homogeneous system of n linear equations represented by A * x = 0, where the original poster seeks to demonstrate that if this system has only the trivial solution, then the system A^k * x = 0 also has only the trivial solution for any positive integer k.
  • Participants discuss the definition of the trivial solution and its implications for the matrix A, including its nonsingularity and invertibility. There are attempts to connect the properties of determinants and the concept of proof by induction.
The conversation includes various interpretations of the problem and explores different mathematical properties related to the matrix A. Some participants have offered insights into the implications of A being nonsingular, while others question whether additional steps are necessary to reach the desired conclusion.
There is mention of the trivial solution being the zero vector and the implications of the determinant of A. The discussion also touches on the potential need for proof by induction, highlighting the complexity of the problem.
soul5
Let A * x= 0 be a homogeneous system of n linear equations in n unknowns, that has only the trivial solution. Show that if k is any positive integer, than the system A^k * X = 0 also has only the trivial solution.
I'm so lost please help and what is trivial solution?
The trivial solution is the vector x = 0. All n entries in this vector are zero.
If A is an n x n matrix, and Ax = 0 has only the trivial solution, what things does that tell you about A?
I am just picking up on what Mark44 said. If the only sol to the matri eq is the trivial one Ax=0, that is for =0,(x-vector, A matrix (nxn), this means that A is nonsingular. Then since A is nonsingular, we know that A has an inverse, a unique one. SO:
[tex]A^kx=0=>A*A*A*A*A*...*Ax=0[/tex] Now multiplying by A^-1 , k-1 times from the left side we get to Ax=0, which as we know has only the trivial sol. so we are set.
But that gets you to Ax = 0. There is one more thing that needs to be done to arrive at the conclusion you want.
Which is?
First, any equation like Ax= 0 has the "trivial solution": it is always true that A(0)= 0. The whole question is whether that is the only solution or whether other solutions exist.
Do you know that Ax= 0 has only the trivial solution if and only if A is invertible? And so det(A)= 0? If you do and also know that det(An)= (det(A))n then the problem is trivial.
If not then proof by induction may be simplest. Since we are given that Ax= 0 has only the trivial solution, the base case, n= 1 is trivial. Suppose Akx= 0 has only the trivial solution. Then Ak+1x= A(Akx)= 0. What can Akx be? And what does that tell you?
  • · Replies 30 ·
  • · Replies 24 ·
