Solving a Non-Exact Differential Equation
The discussion revolves around solving a non-exact differential equation of the form (x+2y-1)dx + 3(x+2y)dy=0. Participants are exploring methods to find integrating factors to make the equation exact.
  • The original poster attempts to identify the equation's form and determine if it is exact by comparing partial derivatives. They express difficulty in finding suitable integrating factors and seek clarification on their approach. Other participants inquire about the specific formulas referenced and suggest examining the homogeneity of the functions involved.
Participants are actively discussing various methods for finding integrating factors, including the use of homogeneity and specific formulas. There is an acknowledgment of the challenges faced, and some participants are exploring alternative approaches without reaching a consensus.
There is mention of potential limitations regarding the scope of the course material, as well as the original poster's uncertainty about their initial approach and the formulas for integrating factors.
rock.freak667
Solve the following
(x+2y-1)dx +3(x+2y)dy=0
I said that it was in form M(x,y) dx + N(x,y) dy=0
then found [itex]\frac{\partial{N}}{\partial{y}}[/itex] and similarly [itex]\frac{\partial{M}}{\partial{x}}[/itex]
Meaning that it wasn't exact, but then tried to find the integrating factors, given that the equation wasn't exact. But in doing so, The formulas for the integrating factors didn't work out. Did I start this question wrong?
Your approach looks correct, why don't you show us your work so that we can see where you may have erred?
What "formulas for the integrating factors" do you mean?
This is from my notes:
If [itex]\frac{\partial{M}}{\partial{y}} \neq \frac{\partial{N}}{\partial{x}}[/itex] i.e. not exact equation
Then an integrating factor is found as follows:
If (i)
[tex]\frac{\frac{\partial{M}}{\partial{y}}- \frac{\partial{N}}{\partial{x}}}{N}=f(x)[/tex]
Where f(x) is a function in x-only , then ef(x) is an integrating factor.
(ii)
[tex]\frac{\frac{\partial{M}}{\partial{y}}- \frac{\partial{N}}{\partial{x}}}{M}= - g(y)[/tex]
then e+g(y) is an integrating factor
______________________________________________________________________________
For (x+2y-1)dx +3(x+2y)dy=0
M= x+2y-1 so that [itex]\frac{\partial{M}}{\partial{y}}=2[/itex]
N=3x+6y => [itex]\frac{\partial{N}}{\partial{x}}=3[/itex] Clearly [itex]2 \neq 3[/itex]
But if I put it into either of the two previously stated formulas, I do not get a function in x only for (i) OR a function in y only for equation (ii)
There is an easier way to find the integrating factor in this case: In general, whenever [itex]M(x,y)[/itex] and [itex]N(x,y)[/itex] are homogeneous functions of the same degree, then [itex]\frac{1}{xM+yN}[/itex] is an integrating factor. So, are [itex]M(x,y)[/itex] and [itex]N(x,y)[/itex] homogeneous functions of the same degree in this case?
M(x,y) isn't homogeneous since it doesn't involve terms in x and y only...
N(x,y) is homogeneous of degree 1
Hmmm.. yes, M is inhomogeneous so that won't work...What other methods have you been taught for finding integrating factors?
Those two are the only two equations which I know of when it is a non-exact differential equation.
I think I got it out. All I needed to do was to put t=x+2y-1
This may be above the scope of your course; but let's look at the definition of integrating factors:
[itex]\mu(x,y)[/itex] is an integrating factor of the ODE [itex]M(x,y)dx+N(x,y)dy[/itex] if the ODE [itex]\mu(x,y)M(x,y)dx+\mu(x,y)N(x,y)dy[/itex] is exact. This means that [itex]\mu(x,y)[/itex]
must satisfy the condition:
[tex]\frac{\partial}{\partial y}(\mu(x,y)M(x,y))=\frac{\partial}{\partial x}(\mu(x,y)N(x,y))[/tex]
Or, equivalently;
[tex]M(x,y)\frac{\partial \mu}{\partial y}-N(x,y)\frac{\partial \mu}{\partial x}=\mu(x,y) \left( \frac{\partial N}{\partial x}-\frac{\partial M}{\partial y}\right)[/tex]
In this case, we have:
[tex](x+2y-1)\frac{\partial \mu}{\partial y}-3(x+2y)\frac{\partial \mu}{\partial x}=\mu(x,y) \left( (3)-(2) \right)=\mu (x,y)[/tex]
Do you have any tools at your disposal that you could use to solve this PDE for [itex]\mu(x,y)[/itex]?
hmmm... yes, that should work!
  • · Replies 18 ·
