Question about commutation and operator
  • Context: Graduate
  • Thread starter Thread starter KFC
    Commutation Operator
The discussion revolves around the application of the angular momentum operator \( J_z \) in quantum mechanics, specifically in the context of bra-ket notation as presented in J.J. Sakurai's book. Participants explore the implications of \( J_z \) acting on bra vectors and the properties of bras and kets.
  • One participant questions how the operator \( J_z \) can act on the bra vector in the expression \( \langle \alpha', jm|J_z A |\alpha, jm\rangle \), noting that \( J_z \) generally does not commute with the operator \( A \).
  • Another participant asserts that it is correct for \( J_z \) to act on the bra vector as described, suggesting a review of the properties of bras and kets to clarify this point.
  • A later reply emphasizes the relationship between bras and kets, mentioning that a bra is a linear function that maps kets to complex numbers, and discusses the notation conventions used in quantum mechanics.
  • Participants reference the property \( J_z^\dagger = J_z \) in the context of their discussion, indicating a recognition of the operator's characteristics.
While some participants agree on the correctness of \( J_z \) acting on the bra vector, the initial question indicates uncertainty regarding this application. The discussion includes both clarification and exploration of the underlying concepts without reaching a definitive consensus.
The discussion touches on the properties of linear operators in quantum mechanics and the nuances of bra-ket notation, which may require further exploration of definitions and conventions in the field.
KFC
I am reading the book by J.J.Sakurai, in chapter 3, there is a relation given as
[tex]\langle \alpha', jm|J_z A |\alpha, jm\rangle[/tex]
Here, j is the quantum number of total angular momentum, m the component along z direction, [tex]\alpha[/tex] is the third quantum number. [tex]J_z[/tex] is angular momentum operator, A is arbritary operator. Generally, [tex]J_z[/tex] is not commutate with A, but Sakurai just give the result directly as following
[tex]m\hbar\langle \alpha', jm|A|\alpha, jm\rangle[/tex]
As you see, this just like have [tex]J_z[/tex] acting on the bar and returns the [tex]m\hbar\langle \alpha', jm|[/tex]. My question is: how can [tex]J_z[/tex] acting on the bar vector?
It is correct to let J_z act on the bra in the way it does. If you are worried about this you can go back to chapter one and review the properties of bras and kets. For example
[tex] \langle \alpha |\beta\rangle=(\langle \beta | \alpha\rangle)^*[/tex]
You can use the above relation to rewrite the quantity of your interest with [itex]J_z^\dagger=J_z[/itex] acting on a ket if you want.
Thank you so much. I forget the relation [tex]J_z^\dagger=J_z[/tex], thanks again :)
you're welcome.
You already got the answer, but you may find this interesting too:
Fredrik said:
A bra is a linear function that takes kets to complex numbers, i.e. it's a member of the dual space H*. There's a theorem that guarantees that for each ket [itex]|\alpha\rangle\in H[/itex], there's a bra [itex]\langle\alpha|\in H^*[/itex] that takes an arbitrary ket [itex]|\beta\rangle[/itex] to the scalar product [itex](|\alpha\rangle,|\beta\rangle[/itex]).
Recall that when T is a linear function acting on x, it's conventional to write Tx instead of T(x). This convention is used with bras. Also, whenever two | symbols should appear next to each other, only one is written out. So we have e.g.
[tex](|\alpha\rangle,|\beta\rangle)=\langle\alpha|(|\beta\rangle)=\langle\alpha||\beta\rangle=\langle\alpha|\beta\rangle[/itex]<br /> <br /> This takes some getting used to. This is one place where it gets confusing: If [itex]X[/itex] is an operator, [itex]X^\dagger[/itex] is defined by<br /> <br /> [tex](|\alpha\rangle,X|\beta\rangle)=(X^\dagger|\alpha\rangle,|\beta\rangle)[/tex]<br /> <br /> but in bra-ket notation, this equation is just<br /> <br /> [tex]\langle\alpha|(X|\beta\rangle)=(\langle\alpha|X)|\beta\rangle[/tex][/tex]
[tex][/tex]
  • · Replies 18 ·
  • · Replies 16 ·
