How do you solve the double integral of xe^(xy) bounded by x=0, y=1, x^2-y=0?
The discussion revolves around solving the double integral of the function xe^(xy) bounded by the curves x=0, y=1, and x^2-y=0. Participants explore different methods of integration and express challenges in finding the limits and evaluating the integral.
  • One participant expresses uncertainty about the limits of integration and mentions difficulties with both x-simple and y-simple methods.
  • Another participant suggests setting up the integral in dy dx order with specific limits.
  • A participant questions the integrability of e^(x^3) in terms of elementary functions, noting that it may not be solvable in that form.
  • Some participants discuss the potential complexity of the integral and suggest that different orders of integration might lead to varying levels of difficulty.
  • A numerical evaluation of the double integral is presented, yielding a complex result, which raises further questions about its completeness.
  • One participant proposes using Taylor series for the integrand as an alternative approach, though they express uncertainty about its effectiveness compared to the integral form.
  • A later reply reveals that the problem may have been an error from the teacher, indicating that it might not be a standard exercise.
Participants do not reach a consensus on the best method to solve the integral, and multiple competing views on the approach and feasibility of the integral remain. The discussion reflects uncertainty and differing opinions on the problem's validity.
Some participants note that the integral may not be solvable in terms of elementary functions and that the integration domain is bounded, which could affect the methods used. There is also mention of unresolved mathematical steps and the potential for different interpretations of the problem.
stanford1463
How do you solve the double integral of xe^(xy)? bounded by x=0, y=1, x^2-y=0. I used both x-simple and y-simple methods but neither worked..I don't know what the limits are...thanks!
You can set up the integral like this for dy dx order...
[tex]\int_0^1\int_{x^2}^1xe^{xy} dy dx[/tex]
Give that a try.
Cool, thanks! I used dy dx order, but cannot find out what the integral of e^(x^3) is..Is it possible?
Well an integral like that is not going to be integrable in terms of elementary functions. I know that something like...
[tex]\int e^{-x^2}dx[/tex]
is an integral that is a gaussian distribution which you can find in a table but that's the closest thing I can think of to the integral you mentioned.
Sometimes it happens, that writing an iterated integral in some order leads into difficult integrals, while writing it in some other order leads into easy integrals. So one should always simply go through different ways of writing the iterated integral. In this case it seems that integrating over x and y in other order doesn't make it easier though... (if I tried it right) so I don't know what to do there.
One alternative is to leave the number
[tex] \int\limits_0^1 dx\; e^{x^3} \in \mathbb{R}[/tex]
in the solution like that.
Well, I did the dy dx order that you mentioned, and the answer came out to be e-1-int (e^(x^3)) (sorry don't know latex). So, I do not know how to solve the integral, from 0 to 1..thanks
^ that above post was for jeffreydk, and for jostpuur, yes I tried both methods, neither worked out. The original problem wanted the volume under f(x,y)=xe^(xy), over region bounded by x=0, y=1, x^2-y=0...so Idk what is wrong.
One idea is to write the integral as an integral of 1 over a subset of [tex]\mathbb{R}^3[/tex].
This is very interesting, because if we get a solution to the original problem, it also gives the precise value of the integral of e^(x^3) over [0,1] in a more explicit form :wink:
Yea that integral is messy. I tried to get a numerical integration of the entire double integral you wanted and it's complex; I get
[tex]\int_0^1\int_{x^2}^1xe^{xy} dy dx = 0.376377+ (3.9255\times 10^{-16})\imath[/tex]
This numerical evaluation doesn't look quite complete :biggrin: You should continue with equation [tex]10^{-16} = 0[/tex] next. :wink:
stanford1463, how did you encounter this task? Is this exercise in some book? I have difficulty believing that this would have been put into a book, because that seriously doesn't look like a kind of integral one could actually calculate.
Or well... since the integration domain is bounded, one way to carry out the integration is to use Taylor series of the integrand, but I'm not sure if having the result in form of series, whose value we don't know in more explicit form, would be any better than having it in a form of integral (whose value is not known in more explicit form).
Well, anyway, like this:
[tex] \int\limits_0^1 dx\; e^{x^3} = \sum_{n=0}^{\infty} \frac{1}{n!}\frac{1}{3n+1}[/tex]
Alright, thanks for the help! Turns out it was a coincidental error by my teacher, who made up this problem.
  • · Replies 24 ·
