Coefficient of friction along an inclined plane
The discussion revolves around a problem involving a block on an inclined plane, where a horizontal force is applied to prevent the block from sliding down. The participants are tasked with finding the coefficient of friction and the acceleration of the block when the force is removed, with the incline angle given as arcsin(7/25).
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the relationship between forces acting on the block, including gravitational force and applied force. There are attempts to calculate the coefficient of friction and acceleration, with some questioning the correctness of their calculations and units.
Some participants have made progress in calculating the coefficient of friction, while others express confusion regarding the application of units and the relationship between forces. There is ongoing exploration of the correct approach to determine acceleration, with no consensus reached yet.
Participants are grappling with unit consistency in their calculations and the implications of mass in the context of force and acceleration. The problem setup includes specific values and conditions that are being scrutinized for accuracy.
Ulti
A horizontal force of 2N is just sufficient to prevent a block of mass 1kg from sliding down a rough plane inclined at arcsin 7/25 (=16.3 degrees) to the horizontal. Find the coefficient of friction between the block and the plane and then acceleration with which the block will move when the force is removed.
Friction = Coefficient of friction x Resistive force (parallel at a right angle to the slope on which the objects acts on)
Force = Mass x Acceleration
Well what I thought was that the force that the object has should be 2+gsin16.3 which equals 4.75N. This means that the acceleration will be 2.75N when the force of 2N is taken away. However the answer is meant to be 1.97ms^-2... Did I work out the acceleration wrong in the first place?
Now attempting to work out the coefficient of friction, I simply did friction over resistive force: gsin16.3/gcos16.3 and that gives me 0.292 but the answer is supposed to be 0.0827... I do not understand what I am doing wrong.
If someone can say what I'm doing wrong and lead me into the right direction then thanks!
EDIT: Worked out coefficient of friction now but can't work out acceleration.
check your units in all your calculations. Sometimes you're missing critical variables and units will help you.
for instance your statement:
"2 + g sin16.3 which equals 4.75N."
is mathematically off in terms of units.
You have the applied force (2N) plus 9.8 m/s^2 times a quantity that doesn't have units. why is this bad: You can't add things with different units together!
then you have this:
"acceleration will be 2.75N"
is that right in terms of units?
Note: units will help you a LOT! So will a free body diagram. It looks, however, that you're headed the right direction. :smile:
Ah I see, so that's where I went wrong on that part, I've drawn a free body diagram but I always thought I could just add the 2N onto it as it is and this is the first time I encountered a problem. (Obviously I made a big mistake when I said the acceleration was measured in N xD)
EDIT: Can't seem to work out the force... Not sure how to turn the 2N force into the same unit... Really confused now :S
Wow I solved the coefficient of friction...
It was (g sin16.3 - 2 cos 16.3)/(-2 sin 16.3 - g cos 16.3) = 0.083
No idea how to work out acceleration still though.
Use F=ma... Force (in N) relates to mass (in kg) times acceleration (in m/s^2).
When you have your free body diagram, you need to have the weight force parallel to the slope as m*g*sin theta... you left out the mass.
Always check units!: in this case: N = kg*m/s^2
Well as mass is 1kg, I can basically ignore it I think. I am correct in thinking that? Still not sure how the units apply here...
Sigh.. still no luck after a few hours. I don't know how many hours I've spent in total on this...
Bump?
  • · Replies 33 ·
  • · Replies 16 ·
