Help with multiple choice question (kinetic energy)
The discussion revolves around a multiple-choice question related to kinetic energy and work done on an object in space, where gravitational potential energy is negligible. Participants explore the implications of the scenario where there is no net change in kinetic energy despite work being done.
  • Participants consider various interpretations of the problem, including the role of friction, the nature of work in relation to kinetic energy, and the potential effects of internal energy changes. Questions arise about the feasibility of friction in space and the implications of work done without a change in kinetic energy.
The discussion is active, with participants offering different perspectives on the relationship between work, kinetic energy, and internal energy. Some suggest that the work done could lead to changes in internal energy, while others question the assumptions about mass and velocity changes. There is no explicit consensus on the correct answer, but various lines of reasoning are being explored.
Participants note that the question is framed within a context that assumes negligible gravitational effects and raises concerns about the definitions of work and energy in this specific scenario. The original poster's understanding of the problem is influenced by prior material focused on translational motion.
FisherDude
Work is done on an object far out in space where it has negligible gravitational-PE. If in the process there is no net change in KE, we can conclude a) friction may have been operative b) this situation is impossible c) the energy of the object has decreased d) the object's speed decreased e) none of these.
I'm guessing it's a), since for an ordinary object on Earth it's possible to do work on it and not change its kinetic energy: if there is kinetic friction working against it, for example. but it says it may have been operative, so does that imply some other force could be acting against the object in space and yet not do any work on it?
Thanks
Think of it in terms of energy conservation, there is an equation relating a bodies potential and kinetic energy with any work done on or by that body;
[tex]K_{1} + U_{1} + W_{other}=K_{2}+U_{2}[/tex]
Consider the potential energy as the bodies internal energy. If the K's are the same what does that tell you about the bodies internal energy?
As for the friction: think about what would provide this friction force in the abscence of gravity. It may help to draw a diagram.
The work caused a change (either positive or negative) in the bodies internal energy?
Also if some other object exerted a force on the body and slid against it, that would cause friction in space right?
That would cause friction in space. But the question satets the mass is far away from any large gravitational effects, so any bodies in it's region must be of comparable size. Now the only way to get a friction force is to press against another body. What happens when you push something in free space, when it's mass isn't much much greater than your own?
Yes the bodies internal energy either incresed or decreased depending on the direction of the force (internal energy being mass energy in this case). Note that the objects total energy has not changed, assuming it's rest mass stays the same.
No friction would occur since the two objects would just move through space as if they were one object...
Also what about random space particles. would they cause a small amount of friction if they slide past the object?
If I'm understanding what you're saying correctly, you're saying that work changed the amount of internal energy in the object. But I was under the impression that forces that take away or increase internal energy don't really count as work since they don't contribute to any translational motion. (Btw, this question was from a chapter that only dealt with work that causes translational motion)
Thanks.
In space the objects would likely move apart as soon as one exerted a contact force on the other (by Newtons third law). Also that work is being done is clearly stated in the question. It is also stated that the kinetic energy hasn't changed. To do work you must change the velocity, at least in this situation. K=1/2*mv^2. So in order for K to be the same the object must have lost/gained some mass, by some mechanism. The work hasn't changed the bodies internal energy, the mass loss/gain has.
ok so basically:
the work changed the velocity and also changed the object's mass so that KE will remain the same but the internal energy changed so the energy of the object changed. the velocity has to increase since there is nothing in space that can counter the object's motion. if the velocity increased then that means the mass has to decrease for the object to have the same KE. So the internal energy decreases. so..the answer is c.
am i right?
Almost. The work didn't change the bodies mass, we don't know what changed the mass. We also don't know if the work speeded up or slowed the body down either, so we can't be certain that there was mass increase or decrease and thus we don't know if the objects (mass) energy increased or decreased. So the answer will be e)none of these.
Hope this helps
oh right. the object could be moving at constant speed and a force could act against it and slow down its speed.
thanks!
