What is vacuum polarization and vacuum de-polarization ?
  • Context: Graduate
  • Thread starter Thread starter PJ2001
    Polarization Vacuum
The discussion revolves around the concepts of "vacuum polarization" and "vacuum de-polarization," exploring their definitions, implications in quantum field theory, and potential experimental observations related to electromagnetic waves. Participants express curiosity about the feasibility of experimenting with these phenomena, particularly from a layman's perspective.
  • One participant asks for a layman's explanation of vacuum polarization and its relation to electromagnetic waves, expressing interest in experimental possibilities.
  • Another participant describes vacuum polarization in the context of quantum field theory, explaining how interactions between particles can be represented through Feynman graphs and how these interactions include contributions from virtual particle pairs.
  • A participant notes that vacuum polarization manifests as an effective change in the electron's charge at higher collision energies, suggesting that this effect is observable only in high-energy physics experiments.
  • There is a suggestion that a related phenomenon, "Polarization of Light by Light," could be more accessible for experimentation without requiring expensive equipment.
  • A later reply corrects the terminology regarding the related phenomenon, referring to it as "Scattering of Light by Light" or Delbruck Scattering.
Participants express varying levels of understanding and interest in the concepts, but there is no consensus on the feasibility of layman-level experimentation with vacuum polarization. The discussion remains unresolved regarding practical experimental approaches.
Participants acknowledge the complexity of quantum theory and the limitations of current understanding, particularly in relation to the experimental observation of vacuum polarization effects.
PJ2001
What is "vacuum polarization" and "vacuum de-polarization"?
Hello,
Could someone explain in laymans terms what is being asked in the subject line and how one experiments with the aformentioned? What I'm really asking is, what relation to electromagnetic waves can we make to vacuum polarization if it really exists? Can we experiment with it?
Thanks
I hesitated responding because this is going to be a bit handwaving, and I'm not sure that I'll do it right. But given that nobody else took this up, here we go.
In (perturbative) quantum field theory, an interaction between two particles is calculated as a sum of contributions, which can be depicted as different interaction schemes. These terms can be calculated easily using formalised drawings known as Feynman graphs. When things (calculations) go right, then the "simplest" interaction schemes are also the most important ones. That means for instance, that you get "most of the answer" by just considering simple, elementary interactions. But, there are small "corrections" due to more complicated interaction schemes.
Let us consider an electron that collides with an electron. The "simplest" interaction scheme is: the incoming electron sends out a virtual photon and that one gets accepted by the target electron. This is the most elementary "electron interacts through electromagnetism with target electron". Just this single interaction scheme gives you, in most cases, already a good part of the final result.
But there are more complicated interaction schemes. For instance, the target electron sends out a virtual photon, that virtual photon splits into an electron-positron pair, then recombines back into a virtual photon which is finally absorbed by the target electron, and the incoming electron sends out a virtual photon which is absorbed by, say, the virtual positron in the created (and annihilated) pair. That's (a priori) a small contribution, but it is there, and it does change the final result a bit.
If you insist on saying that the incoming electron interacts through a simple electromagnetic interaction with the "target" as in the first contribution, then you can picture the second contribution as a kind of "cloud of virtual pairs" swarming around the initial target electron.
Now, as these interactions are always there when there is an electron, you cannot separate the "bare electron" from these extra contributions. Even in complicated interactions, there will always be these extra contributions, so it seems as if a "real electron" is a "bare electron" together with a "cloud of virtual electron-positron pairs" around it. The higher the energy of the incoming particle, the more "obvious" will be this cloud. That's vacuum polarisation.
So it is a way of wanting to think into elementary interactions while in fact the interaction scheme is more complicated.
Thank you so much for your dedication to my question, Vanesch. It seems like we as a humanity have centuries to go before we can even begin to identify and explain all of the pertinent information (no pun intended) when it comes to quantum theory.
Just one last question, is there any way a layman like myself can experiment with anything like this?
At first sight, I would say no, unless you have the capital to build yourself a big particle accelerator (and then I don't think you qualify as a "layman" :smile: ). The main manifestation of vacuum polarization is that the effective charge of the electron seems to change (increase) when you go to higher collision energies. That can be visualized by saying that you "penetrate deeper in the polarisation cloud and see more of the bare charge that was partially shielded by the polarization".
But in order to notice this effect, you need collisions at pretty high energies. You won't see it outside of any high-energy physics experiment (or outside of any high precision experiment at somewhat lower energies).
A probably related phenomenon is the Polarization of Light by Light which would be more reasonable to experiment with without an enormously costly apparatus. Similarly, it is explained and modeled using the concept of virtual photons. When one photon nearly collides with another their trajectories sometimes change in ways that aren't predictable in older QM theory.
Sorry, I got the term a bit wrong. It should be called "Scattering of Light by Light" or Delbruck Scattering (with an umlaut over the u).
  • · Replies 20 ·
  • · Replies 0 ·
  • · Replies 71 ·
  • · Replies 41 ·
