What is the resistance of copper wire?
The discussion revolves around determining the resistance of a copper wire based on its length and resistivity, specifically in comparison to seawater. The original poster presents a scenario involving a 200-meter long copper wire with a resistivity of 0.625x10^-6, seeking to find the wire's cross-sectional area to calculate resistance.
  • Participants discuss the necessity of knowing the cross-sectional area to calculate resistance. There are inquiries about wire gauge numbers and the units of resistivity provided. Some participants attempt to interpret the problem in terms of finding the radius of the copper wire that would have the same resistance as seawater, given specific parameters.
Multiple interpretations of the problem are being explored, with some participants providing calculations based on the resistivity of seawater and copper. There is a recognition of the need to clarify resistivity values and their relevance to the calculations being performed. Guidance has been offered regarding the relationships between resistivity, resistance, and cross-sectional area.
Participants note that the resistivity of copper can vary with temperature, and there is some confusion regarding the resistivity values being used in the calculations. The problem constraints include the specific resistivity values for both seawater and copper, as well as the dimensions provided for seawater.
subopolois
what is the resistance of copper wire in this situation? 200 meters long strand of wire, with a resistivity of 0.625x10^-6
im not sure if this is the right equation but:
resistance=resistivity x length/area
this is the part I am stuck at, i have the resistivity and the length of the wire, but what do i use for the area? this is what i have so far:
resistance= 0.625x10^-6 x 200/area
as you can see i have no idea what area to use?
You can't without the area. does it give you a wire gauge number, like SWG or AWG ?
Unless it's the resistance per unit length.
What units are given - that number doesn't look familair for copper.
well it a problem I am trying to solve, i have to find the radius of the copper wire given the resistivity and length, here is the exact question
what is the radius of 200m of copper wire with the same resistance of sea water? (are sea water=0.25, copper=0.625x10^-6 resisivites
it also gives the dimensions of sea water as 200 m long and a cross section of 1 m^2
So the question is what is the diameter of a copper wire with the same resitivity of a 'wire' of seawater 200m long and 1m^2 CSA?
You simply need the relative resistivity of sea water and copper then work out how many times lower the resistance of the copper is.
yes, how i read the question was: what is the radius of a copper wire with the same resistance of seawater and 200m long, given that the cross section of water is 1 meter square.
i think both of our interpretations are correct. here is the work I've done so far on the question, does it make sense to you?
since the question wants it in terms of same RESISTANCE of sea water i have to find the resistance of sea water, rearranging the equation roe=RS/L (roe= resisivity, R=resistance, S= cross sectional area and L= length) for resistance i get:
R=roe x L/S
= 0.25 ohm.m x 200m/ 1 m^2
= 50 ohm
now i find since i have the resisivity of copper, i rearrange the original equation to solve for the cross sectional area, S:
roe= RS/L
0.625x10^-6= (50)(s)/200
1.25x10^4= 50s
s=2.5x10^-6
since this is the cross sectional area, and i assume the cross section of copper wire is circular, i can use the area of a circle to solve for r:
A=pi r^2
2.5x10^-6= pi r^2
7.96x10^-6= r^2
8.92x10^-4 m= r
so for a radius of copper wire i get 8.92x10^-4 meters or 0.892 millimeters.
does this seem right to you?
Right method, not sure about the answer.
Resistance =[tex]\rho[/tex] * S / A
So if the resistance is equal
[tex]\rho[/tex]w * L / A w=[tex]\rho[/tex]cu * L / A cu
so given that Lenght is the same.
Acu / Aw = [tex]\rho[/tex]cu/[tex]\rho[/tex]w
[tex]\rho[/tex]w = 0.2 ohm m
[tex]\rho[/tex]cu = 1.7x10-8 ohm m, where did you get 0.625x10^-6?
Acu = 1.7x10-8 / 0.2 = 8.5 -8 m2
A = pi r2, so r = 0.1mm
His problem statement gives [itex]\rho_{cu}=0.625 \times 10^{-6} \Omega \text{cm}[/itex]; resistivity is a function of temperature, so this this value is perfectly reasonable.
sorry, what are you trying to say?
Just that you should use whichever value of the resistivity is given to you in the question...mgb gave a different value (1.7 *10^-8 ohm m) for the resistivity of copper, but that value is for copper at about 25C.
the 0.625x10^-6 came right from my question. what are your S, A, and L values represinging ie. roe= resisivity
A = 0.625E-6 / 0.25 = 2.5 × 10-6 m^2
r = sqrt(A/pi) = 0.89mm using your values
alright! so using both your method and mine, either way we get the same answer. thank you to all
Yes - I was confused by the 50 in your calcs - so I wanted to work it through fully to make sure it was correct.
its alright, thank you for your help
  • · Replies 17 ·
23K
