Thread Closed
how to find the radius of copper wire given resistivity values
Share Thread Thread Tools
Nov7-08, 04:05 PM   #1
i need to find the radius of a copper wire given the following data:
resistivity is 0.25 ohm meter
length of wire is 200 m
2. Relevant equations
roe=RS/I
roe=resistivity
R= resistance of material
S=cross sectional area
I= length of specimen
3. The attempt at a solution
i was looking at the equation and noticed i dont have any value for the resistance of the copper, so i looked it up online and it said: 0.00000001678 ohm.m. since i have 200m of wire i multiplied it by 200. so into the equation with everything:
0.25=3.356x10^-6 x s/200 meters
rearranging for the cross section area:
s= 21222410.9
although it doesnt say in the question, i assume that the cross section area of copper wire is circular. so i use the area of a circle to find the radius:
A= pi r^2
r= 2599 m
i dont know about you but this doesnt seem right, to have a wire with radius of 2.5 kilometers. im stuck at what to do, my only guess is that the resistance value is wrong and i know there is and equation for resistance:
resistance= resistivity x length/area
i have the resisivity and the length, but what would i use for area?
help!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Nov7-08, 11:07 PM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
Yeah, 2.5 km for a radius doesn't make much sense. Neither does the question. The resistivity of copper is not 0.25 ohm*m. It's not even close. And if they give you the bulk resistivity and the length, that's just data, it's not a question. You can't determine radius from that. Can you post the question verbatim?
Thread Closed
Thread Tools
Similar Threads for: how to find the radius of copper wire given resistivity values
Thread Forum Replies
[SOLVED] Calculate resistivity of the material of the wire Introductory Physics Homework 3
[SOLVED] Find the diameter of copper wire Introductory Physics Homework 13
copper wire resistance Introductory Physics Homework 6
Resistivity of a wire - AS coursework Introductory Physics Homework 5
Resistance of a sphere of resistivity rho and radius S General Physics 1
