What is the interpretation of a mass term in field theory?
The discussion revolves around the interpretation of a mass term in field theory, specifically focusing on terms like \(\phi^{2}\) in the Lagrangian. Participants explore whether this term universally represents mass and how it relates to particle mass in different contexts, including scalar and fermionic fields.
  • One participant questions why the term \(\phi^{2}\) is referred to as a mass term and seeks clarification on its interpretation.
  • Another participant explains that in free field theory, the coefficient of the \(\phi^{2}\) term corresponds to the mass-squared of the particle, asserting this is a general expression for scalar fields.
  • A follow-up inquiry asks for the derivation that shows the coefficient can be identified with the mass-squared of the particle.
  • One participant provides a derivation using the Lagrangian and plane-wave solutions, concluding that \(p^{2} = a\) implies \(a\) represents mass-squared.
  • Another participant suggests that there are additional steps in the reasoning that have been overlooked, indicating that the relationship between wavevector, frequency, momentum, and energy requires more detailed explanation.
  • A different perspective is introduced, stating that the mass can also be defined as the pole of the propagator in the path integral formalism, linking the quadratic term to the mass term.
Participants express differing views on the completeness of the explanations regarding the identification of the mass term. While some agree on the basic interpretation, others highlight missing steps or alternative perspectives, indicating that the discussion remains unresolved.
Some participants note that the derivation of the mass term involves assumptions about the dimensions and relationships in the equations, which may not be universally applicable without further clarification.
parton
Hello!
I've some problems understanding why in field theory a term (appearing in a Lagrangian) like [tex]\propto \phi^{2}[/tex] is called "mass"-term (whereas [tex]\phi[/tex] denotes a real field). Is there any interpretation? And is this a general expression for a mass term or could it be of any other shape?
Thanks
It's called the mass term because, in free field theory, its coefficient turns out to be equal to the mass-squared of the particle. This is a general expression for the mass term for scalar fields. For fermions, the mass term is [itex]\overline{\psi}\psi[/itex], and its coefficient is the mass (not the mass-squared) of the particle.
Thanks for your answer.
But could you tell me how exactly it turns out that the coefficient can really be identified with the mass-squared of the particle?
Thanks again
write
[tex]L = \frac{1}{2}\left( \partial_{\mu}\phi \partial^{\mu}\phi - a \phi^{2} \right)[/tex]
for some constant a. Clearly it has a dimension of mass squared (the action is dimensionless)
Now put
[tex]\phi = \exp (ipx)[/tex]
in the equation derived from L, i.e.,
[tex]\left( \partial_{\mu}\partial^{\mu} + a \right) \phi = 0[/tex]
you get
[tex]p^{2} (= m^{2}) = a[/tex]
regards
sam
Well, there's a little more to it than that. You've assumed that the wavevector and frequency in a plane-wave solution to the equation of motion for the field are equal to the momentum and energy of a particle (in units with [itex]\hbar=c=1[/itex]). This is of course correct, but there are a few steps missing.
This topic is covered in detail in every QFT book, though.
Given the equation
[tex]\left( \partial^{2} + b \right) \phi(x) = 0[/tex]
it is easy to show that
[tex]\phi^{-}(x) = e^{ip.x} a^{\dagger}[/tex]
is a solution, if and only if
[tex]b = m^{2}[/tex]
The mass of any representation of the Piocare' group is given by the eigenvalue of its Casimir operator
[tex]P^{2}|p \rangle = m^{2}|p \rangle[/tex]
[tex] P^{2}|p \rangle = P^{2} \phi^{-}(x)|0 \rangle = - \partial^{2} \phi^{-}(x) |0 \rangle = b \phi^{-}(x) |0 \rangle = b |p \rangle[/tex]
samalkhaiat said:
write
Now put
you get
regards
sam
Another point of view, in the language of path integral formalism. The mass is defined as the pole of the propagator, where the propagator is the inverse of the quadratic operator in the Lagrangian. Hence, the quadratic term like [tex]m^2\phi^2[/tex] is a mass term.
