Transforming Limits of Integration for Variable Substitution
pleasehelp12
\int\int\int _E\(x^2y}\;dV
Where E is the solid bounded by x^2/a^2+y^2/b^2+z^2/c^2=1
variable substitution x=au, y=bv, z=cw.
I found the jacobian (abc) and I substituted my variables but I can't find the limits of integration. The only equation I have for the limits is u^2+v^2+w^2\leq1. I don't know how to find the limits of integration for u, v, and w individually.
Now switch to spherical coordinates in u,v,w.
First decide on the order in which you want do integrate:
\int dudvdw?
Fine. Project the figure on to the vw plane: v2+ w2= 1. Then project that onto the w line: the segment from w= -1 to 1. The limits on the outer "dw" integral have to be numbers. In order to cover the entire figure, w must vary from -1 to 1. For each w, then v must vary from -\sqrt{1- w^2} to \sqrt{1- w^2}. Finally, for each v and w, u varies from -\sqrt{1- v^2- w^2} to \sqrt{1- v^2- w^2}. Those are the limits of integration.
Of course, because u2+ v2+ w2= 1 is a sphere in uvw-space, spherical coordinates, as Dick suggested, are simplest. The limits of integration would be exactly the same as if it were x2+ y2+ z2= 1.
oh, ok thanks i didn't even think about switching to polor coordinates.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
