How the calculated total velocity derived ?
  • Context: Graduate
  • Thread starter Thread starter Venus50
    Velocity
The discussion centers around the derivation of the formula for total velocity needed for launch from Earth, specifically in the context of the Hohmann Trajectory and the calculation of delta V. Participants explore the relationship between hyperbolic excess velocity, escape velocity, and the energy conservation principle in orbital mechanics.
  • One participant references an article stating the values for Hohmann Trajectory and Earth velocity, leading to a calculated hyperbolic excess velocity and asking for clarification on the derivation of the delta V formula.
  • Another participant provides a derivation based on energy conservation, equating the energy of a satellite at escape velocity with that of a satellite with hyperbolic excess velocity.
  • A later reply acknowledges that a previous participant had already provided the same derivation in another thread.
  • Further details are shared regarding the velocity vector components in hyperbolic and elliptical orbits, including mathematical expressions for these velocities.
Participants do not reach a consensus on the derivation of the delta V formula, as the discussion includes multiple perspectives and references to prior derivations without resolving the underlying questions.
Some assumptions regarding the conditions of the launch and the definitions of the velocities involved may not be fully articulated, and the derivation relies on specific energy equations that may not be universally accepted or understood in the same way by all participants.
Venus50
From the article "Which Way To Mars?. Trajectory Analysis. by Kelsey B. Lynn" that I have read, it states that the Hohmann Trajectory at earth,V1=32.76km/s and the Earth velocity,VE=29.82km/s,so the hyperbolic excess velocity,VH=[V1-VE]=2.940km/s.All these parameters lead to the calculation of the total velocity needed for launch from earth[know as the delta V].To launch from one of the earth'spoles,the delta V is a combination of VH[hyperbolic excess velocity] and VES[escape velocity from earth],that is delta V=[VH^2+VES^2]^.5 =11.6km/s. The value of VES=11.18KM/S,of course.What I would like to know is how the formula{deltaV=[VH^2+VES^2]^.5} is derived? Any help for explanation would be appreciated. Thanks a lot.
Astronomy news on Phys.org
they are derived from the energy equation.
The energy of a satellite can be described using the following formula:
E = 1/2 V^2 - mu/r
For the situation on the surface of the Earth, with a velocity deltaV (on the pole the rocket doesn't get extra velocity due to the Earth's rotation), the energy is:
E_1 = 1/2 (deltaV)^2 -mu/Re
For a parabolic orbit (the satellite is always at the escape velocity), the velocity is zero at infinite distance. When you actually want to go somewhere, you want to have that excess velocity VEH. At r = infinity (you have escaped), the energy is then:
E_2 = 1/2 VEH^2
Energy is conserved after giving the delta-V (assuming the delta-V was there immediately). Equating the two equations gives:
1/2 VEH^2 = 1/2 (deltaV)^2 - mu/Re
it happens to be the case that escape velocity is written as:
VE = sqrt(2*mu/r)
so: mu/Re = 1/2 VE^2
at r=Re
so, finally:
1/2 VEH^2 = 1/2 (deltaV)^2 -1/2 VE^2
or:
VEH^2 + VE^2= (deltaV)^2
et voila
Thanks,remcook. i also see that of Hellfire now.
Velocity vector components from orbital elements
Note that...
a : semimajor axis of the orbit
e : eccentricity of the orbit
1 astronomical unit = 1.49597870691E+11 meters
GMsun = 1.32712440018E+20 m^3 sec^-2
The canonical velocity in a hyperbolic orbit, in general, is found from
Vx’’’ = -(a/r) { GMsun / a }^0.5 sinh u
Vy’’’ = +(a/r) { GMsun / a }^0.5 (e^2 - 1)^0.5 cosh u
Vz’’’ = 0
Where u is the eccentric anomaly and r is the current distance from the sun.
The canonical velocity in an elliptical orbit, in general, is found from
Vx’’’ = -sin Q { GMsun / [ a (1-e^2) ] }^0.5
Vy’’’ = (e + cos Q) { GMsun / [ a (1-e^2) ] }^0.5
Vz’’’ = 0
Where Q is the true anomaly.
The triple-primed vectors would be rotated (negatively) by the angular elements of the orbit (w,i,L) to heliocentric ecliptic coordinates.
Rotation by the argument of the perihelion, w.
Vx'' = Vx''' cos w - Vy''' sin w
Vy'' = Vx''' sin w + Vy''' cos w
Vz'' = Vz''' = 0
Rotation by the inclination, i.
Vx' = Vx''
Vy' = Vy'' cos i
Vz' = Vy'' sin i
Rotation by the longitude of ascending node, L.
Vx = Vx' cos L - Vy' sin L
Vy = Vx' sin L + Vy' cos L
Vz = Vz'
The unprimed vector [Vx, Vy, Vz] is the velocity in the orbit, referred to heliocentric ecliptic coordinates.
Jerry Abbott
