Show Pointwise Convergence of g_n to Zero Function
The problem involves showing pointwise convergence of the sequence of functions g_n(x) = f(x^n) to the zero function on the interval [0,1], where f is a continuous non-constant function with f(0) = f(1) = 0. The original poster also seeks to demonstrate that this convergence is not uniform.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the limits of x^n as n approaches infinity and how this affects the continuity of f at those points. There are attempts to establish pointwise convergence by evaluating specific points, such as x = 1/2, and relating it to the behavior of f at 0. Questions arise regarding the comparison of sup |g_n(x)| and sup |f(x)|, as well as the implications of f being non-constant.
The discussion is active, with participants providing insights and suggestions on how to approach the proof of pointwise convergence and the lack of uniform convergence. Some participants have proposed specific points to evaluate and have raised questions about inequalities involving suprema, indicating a productive exploration of the problem.
Participants note the constraints of the problem, including the continuity of f and the behavior of x^n as n increases. There is an emphasis on the need to show that sup |f(x^n)| is not tending to zero uniformly, and some participants express uncertainty about how to establish certain inequalities.
Carl140
Let f: [0,1] -> R (R-real numbers) be a continuous non constant
function such that f(0)=f(1)=0. Let g_n be the function: x-> f(x^n)
for each x in [0,1]. I'm trying to show that g_n converges pointwise to
the zero function but NOT uniformly to the zero function.
I thought: sup |g_n(x) | = sup |f(x^n)| now if I can only show that this doesn't
tends to zero then we are done but I can't. I also have no idea how to show
it converges pointwise to zero. Can you please help?
Pick a definite point, say x=1/2. What's lim x^n? What's lim f(x^n)?
Ok here's what I think it's a "proof".
To show pointwise convergence:
If x<1 then x^n converges pointwise to 0 , then because f is continuous f(x^n) -> f(0) =0.
But f(x^n) = g_n(x) so g_n(x) ->0 if n->infinity and x<1.
Now if x=1 then g_n(1) = f(1^n ) = f(1) =0 so g_n(1) =0.
Conclusion: g converges pointwise everywhere to 0.
Is this proof correct?
Now to show it is NOT uniformly convergent.
Let x=1/2 then x^n = (1/2)^n = 1/2^n which goes to 0.
Now f(x^n) = f(1/2^n) but then I don't know how to compute this limit.
That's the idea for pointwise convergence alright. To show it's not uniform go back to sup |f(x^n)| over x in [0,1]. How does that compare with sup |f(x)| over x in [0,1]?
Thank you for helping, really appreciated.
I think you suggest to show that sup |f(x^n) | >= |sup(f(x)| but I don't know how
to prove this inequality. Any hints you can please provide?
For every n, find an x such that xn=1/2. Since f is non-constant, you know somewhere f is non-zero, so do the same for that point
I, in fact, think to show sup |f(x^n)|=sup |f(x)|. x goes from 0 to 1, x^n also goes from 0 to 1 for each n. f is going to range over the same values in both cases, isn't it?
Thanks guys, is this correct?
We want to show that sup | f(x^n) | = sup |f(x)|.
Let M = sup |f(x)| which exists because f is continuous and [0,1] is compact.
Now observe that no matter for each x in [0,1] x^n is also in [0,1].
For simplicity let y_n = x^n. Then each y_n is an element of [0,1].
Then by assumption M = sup | f(x) | x in [0,1], so simply "replace" x by y_n.
Then M = sup | f(x^n) | x in [0,1] and we are done (I think)
Is this correct?
One more thing:
To show x^n converges pointwise to zero we shall prove that for all e>0 there
exists natural n>=N such that x^n< e.
n< log(e)/log(x).
So what natural N can we take?
That's coming out a little confusing. I think you just say that range(f)=f([0,1]) for both f(x) and f(x^n). Since as x goes from 0 to 1, x^n also goes from 0 to 1. But for purposes of the proof, all you really need is that sup |f(x^n)| is greater than some positive constant. You could follow Office-Shredder's suggestion and just concentrate on a single nonzero point, if that makes it easier to write down. You might be getting confused in your epsilon proof because log(x) and log(e) are negative. Multiply both sides of n*log(x)<log(e) by -1 to get n>|log(e)|/|log(x)|.
Thanks very much! Got it now.
  • · Replies 18 ·
