How much heat (calories) is required to raise the temperature
The calculation of heat required to raise the temperature of 20 g of water from 15°C to 95°C involves using the specific heat capacity of water, which is 1.0 cal/g°C. The temperature change is 80°C, resulting in a total heat requirement of 2400 calories. The formula Q = mcΔT is applicable when using Joules and kilograms, where 'c' represents the specific heat capacity. This straightforward approach confirms the efficiency of the metric system in thermal calculations.
  • Understanding of specific heat capacity
  • Basic knowledge of calorimetry
  • Familiarity with temperature scales (Celsius)
  • Ability to perform unit conversions between calories and Joules
  • Study the formula Q = mcΔT in detail
  • Learn about calorimetry and its applications in thermal physics
  • Explore the conversion between calories and Joules
  • Investigate the specific heat capacities of other substances
Students in physics or chemistry, educators teaching thermodynamics, and anyone interested in understanding heat transfer and calorimetry principles.
Linzy
How much heat (calories) is required to raise the temperature of 20 g water from 15oC to 95oC? The specific heat capacity of water is 1.0 cal/g*oC.
95-15 = 80oC
80oC *30 g = 2400 cal.
Is that basically what you have to do? Or is there a more formal equation to use?
No - it is that simple.
The definiation of a calorie is the energy needed to heat 1g of water 1deg C - isn't the metric system wonderful!
If you are working in Joules and Kg the equation is Q = mcT Where 'c' is the specific heat capacity - the number of Joules needed to heat 1kg of water by 1deg C.
