Gravitational Field problem Question
The problem involves calculating the gravitational field at one corner of a square due to three masses located at the other corners. The masses include two of mass m and one of mass M, and the task is to express the gravitational field in terms of the edge length l, the masses, and the gravitational constant G.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the vector addition of gravitational fields from the three masses and question the correctness of the gravitational field formula used. There are attempts to clarify the calculation of magnitudes and directions of the gravitational fields.
The discussion includes various interpretations of how to approach the problem, with some participants suggesting different methods for calculating the resultant gravitational field. There is no explicit consensus, but several participants are engaging with the problem and offering insights into the calculations.
Some participants express confusion regarding the magnitude of the gravitational field and its vector representation, indicating a need for clarification on the problem's requirements. There is also mention of differing interpretations based on textbook references.
jessedevin
Three objects -- two of mass m and one of mass M -- are located at three corners of a square of edge length l. Find the gravitational field g at the fourth corner due to these objects. (Express your answers in terms of the edge length l, the masses m and M, and the gravitational constant G).
g=-GM/r2
g= ga+gb+gc
g= Gm/l2 [tex]\hat{i}[/tex]+ (GM/(l[tex]\sqrt{2}[/tex])2)(cos([tex]\pi/4[/tex])[tex]\hat{i}[/tex]+sin([tex]\pi/4[/tex])[tex]\hat{j}[/tex])+Gm/l2 [tex]\hat{j}[/tex]
I know you have to take the magnitude of this, but when I did that , I still get the wrong answer. Here's what I got:
||g||=[tex]\sqrt{2G^2/l^4(m^2+M^2)}[/tex]
Did I start it right? Can someone help?
Isn't the gravitational field given by GM/r ?
You have 3 vectors to add, but happily the 2 m's at right angles gives one lying in the direction of M
So ... √2Gm/L + GM/(√2*L) = √2*G*(m + M/2)/L ?
So do you take the magnitude of that? I am still confused, because my book says otherwise. Can you go through your process?
I think what you did originally is correct, but it ask for the magnitude without the vector sign. So just put down the answer using c^2 = a^2 + b^2 and then I believe you have to indicate the degree according to the x-axis. I'm doing a similar problem. Wait, yeah you did that, never mind.
I got it!
Instead of converting M vectors into g forces of x and y, why don't you convert the other 2 m mass into direction of M which is Gm/l^2 * cos(45) * 2.
Then add it to the g force of M
My answer is (1.41Gm + 0.5GM)/l^2.
Hope it helps, the post was like half a month ago, lol.
  • · Replies 23 ·
  • · Replies 19 ·
  • · Replies 20 ·
