Thread Closed
Curved/warped space time
Share Thread Thread Tools
Nov16-08, 04:17 AM   #1
Hi members,
Can someone tell me the simple analogy of curved time & space.I've searched the google but have not been able to find an A-LEVEL STUDENT stuff.I need an introductory & beginner level idea.Thanks...
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Nov16-08, 11:13 AM   #2
Recognitions:
Gold Membership Gold Member
Have you seen the bowling ball on a stretched rubber sheet analogy? The deformation is analogous to the curving of spacetime....See Wikipedia for "Spacetime"...there is an illustration....
also try for "geodesics" for understanding how "straight lines" become "curved".
Note the "SEE ALSO" section at the bottom of each of the above references for more...
Nov16-08, 11:20 AM   #3
One thing that isn't conveyed by the bowling ball on a rubber sheet analogy is that time moves more slowly the deeper you are in a gravity well, in addition to the force of gravity being present.
Nov16-08, 01:23 PM   #4
Quote by shehri View Post
Brief introduction:
http://www.physics.ucla.edu/demoweb/...spacetime.html
Longer introduction:
http://fy.chalmers.se/~rico/Theses/tesx.pdf (chapter 2)
Interactive visualization:
http://www.adamtoons.de/physics/gravitation.swf
Nov16-08, 01:23 PM   #5
Mentor
Much of what you need to understand about curved spacetime can be understood by considering geometry on the surface of a sphere.
Feb18-09, 05:23 AM   #6
Quote by CaptainQuasar View Post
Hello Captain, I am interested in the curved time component of gravity waves. Since time moves more slowly in curved space-time (relative to time in flatter space-time) does this mean that there is a (tiny) time-slowing effect when a gravity wave passes? If so, could this be measured in a gravity wave detector on earth or would we need a clock well out of the gravity wave to compare our clock with?
I guess the fact that there is only one time dimension would mean that all clocks in the gravity wave would be effected alike whereas with space we can use the different effect on 2 space dimensions to detect a gravity wave in a LIGO.
Feb18-09, 08:18 AM   #7
Recognitions:
Colin.....try Wikipedia at
http://en.wikipedia.org/wiki/Gravitational_Wave
for a decent discussion of gravitational waves, an illustration, and external links at the bottom.
The article mentions the sun/earth gravitational wave power at 313 watts...so its REALLY weak....I assume time would be affected SLIGHTLY but so far nobdoy has even been able to unambiguously detect a gravitational wave let alone second order effects.
Feb18-09, 10:17 AM   #8
Quote by Colin Mitch View Post
No, gravity wave does not cause time to slow down, it only cause the space to warp
See Shutz's book, Gravity from the Ground up
Feb18-09, 12:44 PM   #9
Hi members,
I'll repeat the analogy I've illustrated before.
In the "4D space-time" of GR time is essentially just another "direction" in which an object can move. Supposedly we just can't "see" it because we are "trapped" in a 3D perspective.
So, if we consider a flexible sheet with stick figures drawn on it, and imagine that they can only move on/in the sheet itself, we can see that the inhabitants of "Flatland" have no concept of "up". They can only see directly in front, behind, and to the side of them, but never "up". In this analogy our "dimension" of "time" is similar to the Flatlander's "up".
Now lets say there is a deep depression in the sheet and a Flatlander is down in it. There's another Flatlander outside, in the flat area, watching the trapped one. As the trapped one travels out of the depression s/he is mostly moving "up" instead of across. So, while the trapped Flatlander is making considerable total progress in THREE dimensions, most of it is in the "up" direction which the observer and the trapped cannot perceive. Therefore the observer sees the trapped Flatlander moving very slowly (just a little bit "across" but a lot "up").
As the trapped one escapes the depression the sheet becomes less and less vertical and the outside observer sees him accelerating (he moves more "across" and less "up"). The trapped one could have been moving the exact same speed (in 3 dimensions) all along but because the Flatlanders can't see one of them, they are deceived.
This analogy isn't quite there yet, because in addition to simply moving in an unseeable "up" (or time) direction, the surface on which the trapped Flatlander is moving is stretched. If before the surface was flat with a surface area A, and we placed an object (a circle?) somewhere and caused a depression, we now have a total surface area B>A. So the trapped flatlander not only appears to move more slowly because of his/her progression in an unseeable direction, but actually does move more slowly because the sheet itself is stretched out (a "meter" is "further" now than before).
Feb20-09, 08:11 PM   #10
Quote by feynmann View Post
In that case why is a gravity wave billed as a wave in space-time, not just a wave in space?
Curved space-time slows clocks ie clocks slow in a gravitational field (as compared with clocks out of the gravity field)
That is what makes me think that a gravity wave should slow a clock. Colin
Mar13-09, 06:37 PM   #11
Hi members,
An object no matter what, moves through space and time (unless your thinking of parallel universes) because that's the way it is. if it does't i have no idea what it moves through because every thing is space and time. so a very massive object (i'm using a massive object because that's when gravity is really effective) like the sun warps this "fabric" of space and time, (you can think of space and time as a 2D fabric like the sheet on a trampoline). so an example would be a bowling ball on the trampoline and when an object like a tennis ball representing the earth moves on this fabric it will move on it even if it curves or "warps" (or else it would be in midair). so if the sun curves spacetime, the earth will move on it because again then it wouldn't be traveling through spacetime. since it's curving from it's center, spacetime will curve in that way. so if we travel through spacetime even if it's curved we will curve toward's the object's center. i know my writing didn't flow so much but if you got the idea that's great.
Mar18-09, 03:39 PM   #12
As i understand it with the rubber sheet bowling ball analogy gravity is due to the curvature of time and not due to a force is that right?
Mar18-09, 04:02 PM   #13
Quote by Dreads View Post
Yes, curvature of time is crucial. Unfortunately the rubber sheet bowling ball analogy doesn't show it, as it doesn't contain the time dimension. For better analogies follow the links in this post:
http://www.physicsforums.com/showpos...92&postcount=4
Mar18-09, 04:12 PM   #14
if gravity is due to curved time I take it moving towards a mass does not involve work (ie no energy is expended by either mass) as there is no force involved ?
But if this is the case how come moving away from a mass does involve work?
Mar18-09, 04:40 PM   #15
if gravity is due to curved time I take it moving towards a mass does not involve work (ie no energy is expended by either mass) as there is no force involved ? But if this is the case how come moving away from a mass does involve work?
You need a force to make a mass follow a non geodesic(curved) path in space time. Work is done if the mass moves in space in the direction of that force.
Mar18-09, 05:14 PM   #16
Quote by A.T. View Post
Is space and time curved or only time?
If a meteorite is moving in a straight line(ie direct hit) towards the earth then is it following a geodiesic path? I say it must be as no external force is acting on the merteorite and it is simply following curved time. Therefore do you agree a straight line is a geodiesic path?
Assuming you agree with the above from your logic
if a meteorite (M) moves towards earth (E) following a geodeisc path, energy expended by E = 0 energy expended by M = 0
if a meteorite (M) moves towards earth (E) following a striaght line (ie direct hit) as a striaght line is a geodiesic, energy expended by E = 0 energy expended by M = 0
Now if I move a meteorite (M) AWAY from the earth (E) along a geodeisc path energy expended by E = 0 energy expended by M = 0 energy expended by me = 0
and
if I move a meteorite (M) AWAY from the earth (E) in a striaght line (ie a line perpendicular to a 2d tangential plane to the surface of the earth), as a striaght line is a geodeisic path, you are saying energy expended by E = 0 energy expended by M = 0 energy expended by me = 0
I disagree
if I move a meteorite (M) or anything for that matter AWAY from the earth (E) in a striaght line (ie a line perpendicular to a 2d tangential plane to the surface of the earth) then energy will be expended and energy expended by E = 0 energy expended by M = 0 energy expended by me > 0
Further I contend if I move any mass away from any other mass along any path, as long as the nett distnace between the two massess is increasing, then energy will be expended
Mar18-09, 06:21 PM   #17
Both, but space curvature is not so relevant for gravity. Look here
IIf a meteorite is moving in a straight line(ie direct hit) towards the earth then is it following a geodiesic path? I say it must be as no external force is acting on the merteorite and it is simply following curved time. Therefore do you agree a straight line is a geodiesic path?
You have two things here:
- The path of the meteorite in space, which is a line
- The path of the meteorite in spacetime, which is a geodesic
For the free fall case they are both geodesics, but not for the lift case:
No. If you apply a force to move the meteorite away of the earth, its path in spacetime is not a geodesic, even if the path in space is a geodesic (a line ).
Thread Closed
Thread Tools
Similar Threads for: Curved/warped space time
Thread Forum Replies
Gravitons or Warped Space-Time? Special & General Relativity 40
Curved Space-Time question. Special & General Relativity 4
