inertial frame of reference
by alpha372
Tags: frame, inertial, reference
alpha372
alpha372 is offline
#1
Nov16-08, 12:47 PM
P: 43
What is an inertial frame of reference?
2. Relevant equations
-A particle at rest or moving at a constant velocity in an inertial frame of reference implies that the sum of the forces acting on the particle is zero
-The tendency of a body to keep moving once it is set in motion results from a property called inertia.
3. The attempt at a solution
My best guess is that it is a location in space where internal or external forces are not acting on it.
Phys.Org News Partner Science news on Phys.org
SensaBubble: It's a bubble, but not as we know it (w/ video)
The hemihelix: Scientists discover a new shape using rubber bands (w/ video)
Microbes provide insights into evolution of human language
HallsofIvy
HallsofIvy is online now
#2
Nov16-08, 12:49 PM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 38,898
Why guess? That's just asking for a definition. You can probably look it up in the index of your textbook.
alpha372
alpha372 is offline
#3
Nov16-08, 01:09 PM
P: 43
My text just says, "A frame of reference in which Newton's first law is valid is called an inertial frame of reference." But, it doesn't give specific if then conditionals on the the phrase "in which Newton's first law is valid." For instance, it doesn't say, newton's first law is valid if.... or, "newton's first law is not valid if..."
Although, with a bit more reading, the text seems to hint that a frame which is accelerating is not an inertial frame of reference. I would like some verification for this, because the book doesn't just come right out and say it; I tend to have a preference for outright definitions.
The 'Hoff
The 'Hoff is offline
#4
Nov16-08, 02:39 PM
P: 6
A simple phrasing of Newton's first law is "Objects will not change velocity unless acted upon by a force". Velocity is relative to your frame of reference.
Suppose you have a brick just floating there in space, light years from the nearest gravity well, for all intents and purposes unaffected by outside forces. Further suppose you arbitrarily accelerate your frame of reference to 200 miles per hour in some random direction. The brick has now changed velocity in your frame, despite not having been acted upon by a force.
So, no, accelerating frames are not inertial. As for definitions, Newton defined inertial frames as frames not accelerating relative to "the fixed stars", but that formulation is a bit out of date.
Register to reply
Related Discussions
What is an inertial reference frame? Special & General Relativity 7
inertial reference frame Special & General Relativity 15
Inertial Reference Frame Special & General Relativity 15
Inertial Reference Frame Introductory Physics Homework 16
non-inertial reference frame Classical Physics 1
