| Thread Closed |
single piston engine problem - position of piston |
Share Thread | Thread Tools |
| Nov19-08, 07:25 PM | #1 |
Consider the simplified single-piston engine in the figure. The wheel rotates at a constant angular speed of 1 rad/s and the radius of the wheel is 2 m. If the piston is fully extended at time t=0, find the position of the piston at 2s. The figure depicts a wheel with a peg that draws a piston in and out of a bore as the wheel rotates (counter clockwise, with the piston horizontal to the right). 2. Relevant equations x=A cos (omega*t) where A is the radius of the wheel 3. The attempt at a solution omega*t = 2rad cos 2 * 2m = x. since 2 > pi/2, I add 2meters to the resulting x. The answer I get is reportedly wrong. what's wrong with my approach? |
| Nov19-08, 07:44 PM | #2 |
Mentor
It would help to see a diagram, but are you taking into account the angle of the connecting rod? When the pin is not at 0 or PI, you lose some of the stroke distance since the pin is above or below the axis of the cylinder.
| Nov19-08, 07:45 PM | #3 |
Mentor
Actually it looks like you are trying to include that factor, but the distance x is not cos(2rad*2m). I don't think that's the angle that you should be taking the cos of...
| Nov19-08, 08:30 PM | #4 |
after doing some searching, I was able to find another problem with an identical diagram.
http://faculty.ksu.edu.sa/alkurtass/Tut102/Tut102-9.pdf problem number 7 shows the piston and the wheel. my thinking of the angle being 2 rad stems from the piece that catches on the piston assembly following the path of the wheel. Since the piston is fully extended at time t=0, I believe that puts the initial angle at 0. am I wrong in thinking so? |
| Nov20-08, 12:07 AM | #5 |
Mentor
At t=0, the pin is at the far right. At 2s into rotation, the wheel is 2 radians CCW, which is most of the way to PI radians which is the farthest left. The x displacement to the left of the piston is most of the way to max displacement possible, but a little less. To calc the displacement x, draw a triangle. The theta that you take the cos of is most definitely not 2 radians. Draw the triangle on that figure, and show us your calculation...
| Nov20-08, 12:09 AM | #6 |
Mentor
| Nov20-08, 01:14 AM | #7 |
Sorry to intrude, but what is it? I have the same problem, with the same omega = 1 rad/s, but my r = 1.3m.
I am trying x = Acos(pi - 2rad) but this is not working. I have drawn a little triangle and concluded that the angle is pi minus omega(t), but no bueno! Any suggestions would be greatly appreciated |
| Nov20-08, 11:18 AM | #8 |
Mentor
| Nov21-08, 09:13 PM | #9 |
For the sake of posterity and future students facing this kind of problem, I thought I'd post an update. It turns out that because the piston is fully extended at time t=0, the answer is simply x=A cos (omega*t). I was making the problem more difficult than it needed to be. In this case, the answer is -.83 meters
| Thread Closed |
| Tags |
| single piston engine |
| Thread Tools | |
Similar Threads for: single piston engine problem - position of piston
| Force pushing against piston in car engine | General Engineering | 7 | ||
| Why Does the Torque Curve Drop Off at Low RPM in a Typical Piston Engine? | Mechanical Engineering | 15 | ||
| Physics of a piston engine... | General Physics | 2 | ||
| Piston & Gas Law Problem | Introductory Physics Homework | 1 | ||
| Derving piston position and instant velocity | Mechanical Engineering | 1 | ||
