Premium electromagnet core material
The discussion revolves around sourcing premium core materials for a pulse coil electromagnet design. Participants explore various materials and their properties, focusing on achieving the strongest electromagnet per watt in a low-cycle application. The conversation includes considerations of material performance, sourcing challenges, and specific dimensions for the electromagnet core.
  • One participant seeks recommendations for the best core material for a pulse coil electromagnet, currently using a grade 2 hex bolt and looking to upgrade for better efficiency.
  • Suggestions include using soft grain oriented silicon steel alloy, laminated into leaves, and stacking transformer EI cores for a square cross-section core.
  • Another participant mentions the high relative permeability of grain oriented silicon steel and supermalloy, but emphasizes the challenge of sourcing these materials in small quantities.
  • Concerns are raised about the cost and availability of premium materials, with specific references to suppliers like Carpenter Steel and Surepure, noting their limitations in small orders and annealing requirements.
  • One participant shares experiences with obtaining prototype size orders from Toshiba America and suggests checking with Digikey for electronics parts, although unsure about core materials.
  • There is a discussion about the dimensions of the desired core, with suggestions to consider scrap transformers for sourcing materials.
Participants express varying opinions on the best core materials and sourcing options, with no consensus reached on a single optimal solution. The discussion remains unresolved regarding the ideal material and supplier.
Participants highlight limitations in sourcing premium materials in small quantities and the need for further annealing to achieve desired magnetic properties. There are also unresolved questions about the performance of suggested materials in relation to the specific application.
capthook
I'm trying to get feedback on electromagnet design and specifically sourcing premium core material for a pulse coil electromagnet. I have seen this question asked a few times on this forum, but doesn't appear to have really been answered.
What is THE BEST core material and where to source small quantities? Links? Suppliers?
To make the most efficient and strongest electromagnet I am wondering what I should be looking for in core material. The cores will be 3/8" x 2" wrapped with 1200 turns #24 AWG magnet wire. This will be a DC circuit with voltages around 3volts @ .5 amps.
Hysteresis and eddy currents aren't an issue as it is a low-cycle application. Strongest electromagnet per watt is the primary goal.
Currently I am using a grade 2 hex bolt, permeability of 50-100u, so I'm looking to increase efficiency by upgrading core material.
99.99% iron and electrical steel are two possible choices I have considered (2000u?), but are difficult to source in small quantities.
Does anyone have links/suppliers for these?
(http://www.surepure.com/products.php?ID=7&meas1_ID=41&subCat=23 @ $96!)
What about 1018 cold-rolled steel?
I have also tried 2000u ferrite rods with very poor results - you would think the high permeability would make a good core - but it seems to just 'suck up' the flux rather than transmitting it.
Mu-metal, Somalloy, Permalloy, Powdered Iron cores etc. seem as though they would perform like the ferrite rods - high permeability but low performance? Due to low saturation points?
And these high u materials seem to be used mostly as shielding etc. not cores.
Please help me figure on the best core material and where to source it in small quantities!
Thanks!
CH
Try soft grain oriented silicon steel alloy, laminated into leaves.
I dunno. Buy a bunch of Is for transfromer EI cores and stack them into a square crossection core if you can.
Hmm. A little research shows the relative permeability, u/u_0, of grain oriented silicon steel at 40,000, and supermalloy at 1^10^6.
Hi Phrak - thanks for the reply!
The problem is how to source a premimum material in small quantities, that is fully annealed and doesn't totally break the bank...
Carpenter Steel offers some great (expensive) stuff and good info.
This is a great read on core materials:
http://www.cartech.com/techarticles.aspx?id=1624
Sound like their Vacumet Core Iron or the Silicon Core Iron C would be EXCELLENT cores.
(if one could get a small quantity AND it was fully annealed )
They only offer large orders directly and all the materials need further final annealing.
edfagan.com and frysteel.com were offered as small suppliers when I spoke to them, but they don't offer the premimum em core materials and still not annealed.
Frysteel: $30 per ft. plus $40 packing cost plus $9 per cut (1' to 6' rods) plus shipping
(think I'll call Carpenter Steel again about suppliers - it seems their stuff rocks!)
Surepure offers .5" x 1' rods of 99.9% iron at $96
CMI (http://www.cmispecialty.com/index.cfm )
Their min. order is $250 (50 lbs) plus shipping (a lot for 50 lbs.) and all their stuff then needs to be further annealed to realize it's full magnetic properties... (yeeessh)
And getting them on the phone or their material spec. sheets is like pulling teeth!
I guess a visit to junkyard for some microwave laminations to hack apart is on the list for next week...
no problem, glad to help.
I used to obtain prototype size orders directly from Toshiba America. Same story from a small time distributor working out of his garage. Things have changed. Have you tried Digikey? They sell electronics parts. I don't know about core material.
From what I gather, you don't have a target minimum permeability or flux density--just the maximum that you can practically get.
Your target dimensions of 3/8 by 2" is kind of slender for off-the-shelf EI core leaves. Too bad. Could you series the I's to make them twice as long? If that's the case, you might look for some scrap transformers about an inch and a half on a side.
  • · Replies 61 ·
11K
9K
26K
14K
14K
