Differentiability of Inverse Map in Bounded Linear Transformations
  • Thread starter Thread starter symbol0
    Differentiable
The discussion revolves around the differentiability of the inverse map defined on the set of invertible bounded linear transformations from a Banach space V to itself. Participants are tasked with showing that the inverse map is differentiable at each invertible transformation.
  • Participants explore the definition of the derivative in the context of the inverse map and discuss the continuity of the map. Questions arise regarding the existence of limits and the form of the derivative. Some participants attempt to derive a linear function related to the inverse operation.
There is ongoing exploration of the derivative's form and its implications. Some participants have provided insights into the linearity of the derivative, while others express confusion about the relationship between the derivative and the inverse operation. The discussion remains active with various interpretations being considered.
Participants note the need for clarity regarding the topology of the Banach space V and the implications of the linear transformations involved. There is also mention of specific homework rules that require showing work and justifying steps taken in the reasoning process.
symbol0
Let B(V,V) be the set of bounded linear transformations from V to V. Let U be the set of invertible elements of B(V,V) and define the map [tex]^{-1}[/tex]: [tex]U\rightarrow U[/tex] by [tex]^{-1}(T)=T^{-1}[/tex]
Show that the map [tex]^{-1}[/tex] is differentiable at each [tex]T \in U[/tex].
For us to be able to help you, you would first have to show your work. Moreover it wouldn't hurt to say what V is. It surely has some topology?
The only information I have about V is that V is a Banach space. Also, I know that [tex]^{-1}: U\rightarrow U[/tex] is continuous.
I tried to use the definition of derivative. So the map [tex]^{-1}[/tex] would have a derivative [tex](^{-1})'(T)[/tex] at each T in U if for T,S in U, [tex]S^{-1}=T^{-1}+m(S,T)(S-T)[/tex] and
[tex]lim_{S\rightarrow T} m(S,T)= (^{-1})'(T)[/tex].
Then [tex]m(S,T)=(S^{-1} -T^{-1})(S-T)^{-1}[/tex]. So
[tex](^{-1})'(T)=lim_{S\rightarrow T} m(S,T)=lim_{S\rightarrow T}(S^{-1} -T^{-1})(S-T)^{-1}= lim_{S\rightarrow T}-S^{-1}(S-T)T^{-1}(S-T)^{-1}[/tex]
but what is this limit? or how do I know it exists?
By the way, a part b of the question says: show that [tex](^{-1})'(T)(U)=T^{-1}UT^{-1}[/tex].
You want a linear function A_x such that lim |(x+h)^(-1)-x^(-1)-A_x(h)|/|h| -> 0 as |h|->0. (x+h)^(-1)=(x(1+x^(-1)h))^(-1)=(1+x^(-1)h)^(-1)*x^(-1). Now use the good old reliable 1/(1+S)=1-S+S^2-... Can you see what A_x(h) is?
Hi Dick,
Can I see what A_x(h) is?
No, I can't.
I get the part of (x+h)^(-1)=(x(1+x^(-1)h))^(-1)=(1+x^(-1)h)^(-1)*x^(-1).
But then you say: Now use the good old reliable 1/(1+S)=1-S+S^2-...
where do I use that? You mean use that on (1+x^(-1)h)^(-1)?
but then how do I get to A_(x)?
HEEELP
Sure. (1+x^(-1)h)^(-1)=1-x^(-1)h+(x^(-1)h)^2- ... The linear function A_x(h) has to be the part of (x+h)^(-1)-x^(-1) that is linear in h (i.e. first power). Parts that don't have an h in them have to cancel and higher powers of h will go to zero as h->0.
Let' see,
the term linear in h is -x^(-1)hx^(-1).
Is [tex](^{-1})'(T)=T^{-1}T^{-1}[/tex]?
but then [tex](^{-1})'(T)(U)=U^{-1}T^{-1}U^{-1}T^{-1}[/tex] and part b of the exercise says show [tex](^{-1})'(T)(U)=T^{-1}UT^{-1}[/tex]
Good! The linear term is A_x(h)=-x^(-1)hx^(-1). That's your derivative. In the notation of the second part, you've shown:
[tex] (^{-1})'(T)(U)=(-1)*T^{-1}UT^{-1}[/tex]
I think the exercise answer is missing that (-1) factor.
aahhhhh?
now I'm really confused.
Can you please write the same in terms of [tex]T\in U[/tex].
I mean, for each [tex]T\in U[/tex], [tex](^{-1})'(T)=[/tex] ?
You are confused, and I'm not surprised. W=(^-1)'(T) is a linear function from B(V,V) to B(V,V) defined for each T in U. To say what W is you have to say how it acts on an A in B(V,V). W(A)=(-1)*T^(-1)AT^(-1). Try relating this to ordinary derivatives on R. If f'(x)=m, then |f(x+h)-f(x)-m*h|/|h| goes to zero as h goes to zero (everything ordinary numbers). If f(x)=1/x, then the derivative m at x=a is -1/a^2. So m*h=(-1)(1/a)*h*(1/a). Do you see how that relates to your problem? The fact linear transformations don't commute makes it a little different. But only a little.
Hi Dick,
First of all, thank you for your help.
I see how your example relates to the problem.
It just seems weird to me that if you can define (-1)(T) as (-1)(T) =T^(-1) (without using an aditional element A), you say that we can't do the same for the derivative. That is, to give the derivative at T without using some additional element A.
I'm not sure about the following:
Wouldn't the derivative of T be (-1)'(T)= -T^(-1)T^(-1) because if (-1)'(T)(U)= -T^(-1)UT^(-1) then (-1)'(T)= (-1)'(T)(I)= -T^(-1)IT^(-1)= -T^(-1)T^(-1).
Perhaps the derivative can be expressed as (-1)'(T)= -(*T^(-1))(T^(-1)) where (*w)(v)=v*w. So for example
(-1)'(T)(U)(V)= -(*T^(-1))(T^(-1))UV= -(*T^(-1))(T^(-1)UV) =-T^(-1)UVT^(-1).
I'm not really sure where you are going there. But I'm pretty sure (^(-1))'(T)(U)=-T^(-1)UT^(-1). We got that out of the linearized form of (^(-1)) and being careful about order. For derivatives in R, you can be careless about the ordering. Here you can't. (^(-1))'(T) is supposed to be a linear operator from B(V,V) to B(V,V), so it has to act on something. -T^(-1)UT^(-1) is not the same as -T^(-1)T(-1)U. If U=I, it is, but that's not true in general. The derivative here is an operator.
  • · Replies 24 ·
  • · Replies 16 ·
