Do i have to consider the complex case of triangle inequality
The discussion revolves around the triangle inequality in the context of complex vectors and inner products. Participants are exploring the definitions and implications of the triangle inequality as it relates to vector addition and complex numbers.
  • Participants are questioning whether vectors should be considered as complex numbers and discussing the structure of the inner product. There is also confusion regarding the application of the triangle inequality, particularly why the sum of two sides can equal the third side in certain cases.
The discussion is active, with participants providing insights and clarifications regarding the definitions involved. Some guidance has been offered about interpreting vectors and the conditions under which the triangle inequality holds, but no consensus has been reached on the complexities of the topic.
There are indications of confusion regarding the definitions of the vectors and the conditions under which the triangle inequality applies, particularly in the context of complex numbers and linearity.
transgalactic
in order for me to understand this theorim
do i have to think of the vectors as complex??
what the values of x1 ,y1 ,x2 ,y2
[tex] \langle x , y \rangle = x_1^* \cdot y_1 + x_2^*\cdot y_2 + \ldots [/tex]
did i get the structure correctly
x=(x1,y1) y=(y1,y2) each one of x1,x2,y1,y2 is a complex number??
That has not much to do with any triangle inequality, but yes, it looks like the definition of a complex inner product. And I think your understanding of what the objects are is fine.
i know that the sum of two sides is always bigger then the third one
but in this formula
|x+y|=<|x| +|y|
on both sides i have a sum of two members
why the third side is |x+y| ??
and why there is an option for them to be equal??
(the sum of two sides is always bigger then the third one)
You are supposed to be thinking of x and y as vectors. If the vector x represents one side and the vector -y represents the other side, x+y represents the third side. The sum of the sides can be equal to the third side if all three vertices lie on the same line.
in the article they present the case where they use it in a simple way of
|x+y|=<|x| +|y|
http://en.wikipedia.org/wiki/Triangle_inequality
if both the sides lie on the third line then its not a triangle(its not legal)
10K
