Thread Closed
The propagator
Share Thread
Nov23-08, 02:37 AM   #1
The propagator
This might turn out to be a stupid question but ...i couldnt understand
The propagater is defined as exp[-iHt/(h/2pi)]...this would be the matrix
so U(t)|[tex]\psi[/tex](x,0)> (matrix . vector) would give |[tex]\psi[/tex](x,t)>
What i couldn't understand is that the propagator is a diagonal matrix..but it is obvious that
probability of a particle at x,t will be affected by the entire wave distribution.
PhysOrg.com physics news on PhysOrg.com
>> Kenneth Wilson, Nobel winner for physics, dies
>> Two collider research teams find evidence of new particle Zc(3900)
>> Scientists make first direct images of topological insulator's edge currents
Nov23-08, 04:15 AM   #2
Recognitions:
Homework Helper Homework Help
First of all, why do you say that the propagator is a diagonal matrix? In general, in "real" space it is not (while in momentum space, it is, as momentum states have a well-defined energy hence are eigenstates of the Hamiltonian).
Secondly, note that x is just some label here, the dynamics is in the time variable.
Finally, if you consider a string with a wave propagating in it, you will see that it is perfectly possible to describe the motion of each point on the string without referring to other points on it, for example u(t) = cos(t/f - kx), for fixed x.
Nov24-08, 05:27 AM   #3
I am a total beginner so there are some leaps in my logic.
In real basis the propagator turns out to be sigma over n of (h^2/2m) d^2n/dx^2n for the diagonal terms rest terms being zero. hence the doubt.
The thing about the string was ok for the classical case, but in the quantum case
the probability at x at a later time would be integral( <x|U|x'><x'|psi(x,0)>).
That is there is a contribution from each point in space to the probability distribution that would exist at (x,t).
Hence i felt there should be off diagonal terms.
The problem is also that if you take it in the p basis and then take x components you get non zero terms but in the real basis i was not able to understand how the off diagonal terms are non zero.
Thanks for your help compuchip. please let me know, even if i have made some real sad mistake in calculations
Thread Closed
Similar discussions for: The propagator
Thread Forum Replies
QED propagator Advanced Physics Homework 13
Propagator equation Advanced Physics Homework 3
Why adj( U(t)) * U(t) = I where U(t) is a propagator in QM? Quantum Physics 4
Propagator equation Quantum Physics 9
what is propagator Quantum Physics 5
