Moment of Inertia of a Physical Pendulum?
The discussion revolves around calculating the moment of inertia of a physical pendulum consisting of a uniform ruler and an attached weight. The original poster describes the setup, including dimensions and weights, and expresses uncertainty about how to proceed with the calculations.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants suggest finding the center of mass and applying Steiner's theorem. There are discussions about calculating the moment of inertia for both the ruler and the weight separately, and how to combine these results.
Some participants have provided guidance on using the parallel axis theorem and calculating individual moments of inertia. There is ongoing exploration of the calculations, with participants questioning the accuracy of the results compared to experimental data.
The original poster mentions being "clueless" about the problem, indicating a lack of prior attempts or understanding. There is also a concern about discrepancies between calculated and experimental results, suggesting potential issues with the experimental setup or assumptions made during calculations.
Waich
I have a uniform ruler, 80cm long weighing 50g. I'm attaching a weight at one end, 1cm from the bottom. I'm assuming that its a point mass to make things easier. This weighs 10g. The ruler has an axis 5 cm from the top. What's the moment of inertia?
None yet :S I'n pretty clueless about how to do this
Find out the center of mass of the system. After you've done that, apply Steiner's theorem to determine the moment of inertia of the system. Consider the pendulum as being a point situated in the center of mass.
I can work out the centre of mass (it's 33.5cm from the bottom) but I don't know how to work out the moment of inertia from there.
Also, the pendulum can't be thought of as a point mass otherwise it turns into a simple pendulum (although I wish it could, this would be a hell of a lot easier :frown: ).
Sorry from there you don't have to use Steiner's theorem. It's even more simple.
The moment of inertia with respect to an axis passing by the upper point of the pendulum is worth [tex]\int r^2 dm[/tex]. You have a point so it is simply worth [tex]d^2M[/tex] where M is the mass of the system and d is the distance between the upper point and the center of mass.
I hope I'm not wrong...
Can you find the rotational inertia of the ruler by itself about the given axis? (You'll need the parallel axis theorem, also known as Steiner's theorem as fluidistic said.) The rotational inertia of the mass by itself?
Find the separate rotational inertias and add them up for the total.
Well using the standard result for the moment of inertia at the centre of mass I get this:
I = 1/12 * ML[tex]^{2}[/tex] + Mr[tex]^{2}[/tex]
I = 1/12 * 0.05 * 0.8[tex]^{2}[/tex] + 0.05 * 0.415[tex]^{2}[/tex]
I = 0.01128
Then for moment of inertia of the weight I get this:
I = m * x[tex]^{2}[/tex]
I = 0.01 * 0.74[tex]^{2}[/tex]
I = 0.005476
So Total Inertia = 0.0168
Does this seem right?
I've tried subbing it into the Time Period equation (T = 2[tex]\pi[/tex][tex]\sqrt{\frac{I}{Mgr}}[/tex] )
but I get different values to my experiment results. It's out by around 0.3 seconds, I don't think my results are that bad :S Have I done the calculation properly?
Good.
I = 0.01128
What's the distance between the center of the ruler and the axis?
I = 0.005476
Looks good.
You'll need to recalculate that.
What did you use for the distance between center of mass and axis of rotation?
Ah right so the r in my second line of working should be 0.35m. However, it's still a little off :(
I'm using 0.415 as the distance between CoM and the axis.
I'm starting to think that my experimental values are off...
