Is There a More Efficient Way to Prove a Homomorphism in Z_10->Z_10?
  • Context: Graduate
  • Thread starter Thread starter sutupidmath
The discussion revolves around the proof of a homomorphism from Z10 to Z10, specifically the mapping defined by θ(𝑚) = 5𝑚. Participants explore different approaches to proving this mapping is a homomorphism, debating the elegance and efficiency of various proof methods.
  • One participant describes a proof method that involves considering cases based on whether elements are even or odd, questioning its elegance and correctness.
  • Another participant agrees that the proof is correct but describes it as long-winded, suggesting that a more concise proof would be preferable.
  • A third participant expresses a preference for longer proofs, indicating enjoyment in exploring unconventional methods, despite acknowledging that they may be less elegant.
  • One participant critiques the original proof for being difficult to follow due to its length and case division, while providing a shorter proof that preserves addition and multiplication more straightforwardly.
  • There is a mention of the importance of context regarding whether rings require a multiplicative identity for the classification of homomorphisms.
Participants generally agree that the original proof is correct but disagree on its elegance and efficiency. There is no consensus on the best approach to proving the homomorphism, with multiple viewpoints on the value of longer versus shorter proofs.
Participants note that the proof's complexity may increase with different mappings, and the discussion hints at the potential for varying definitions of homomorphisms based on the presence of a multiplicative identity.
sutupidmath
Dilema about Z_10--->Z_10??
What if somebody asked you to show that the following is a homomorphism
[tex]\theta:Z_{10}->Z_{10}, \theta(\bar m)=5\bar m[/tex]
I already know how to show this one in an elegant manner, it is not difficult at all. But i am wondering if you would chose a hard way to prove it, like i am going to describe the following, what do u think is that correct?
[tex]Z_{10}=\{\bar 0,\bar 1,\bar 2,\bar 3,\bar 4,\bar 5,\bar 6,\bar 7,\bar 8,\bar 9\}[/tex]
THe way i choose to do this is by first observing that for any element [tex]\bar a \in Z_{10}[/tex] if a=2k then [tex]\theta(\bar a)=\bar 0[/tex] if a=2k+1 then [tex]\theta(\bar a)=\bar 5[/tex]
So. in order to prove that it preserves addition, we would take the following cases.
Let [tex]\bar a, \bar b \in Z_{10}[/tex]
1. a=2k, b=2k
2.a=2k, b=2k+1
3.a=2k+1, b=2k+1
Do the same to show that it preserves the multiplication. And show that in all these cases it preserves both operation.
SO, i know that this might not be elegant at all, but how would you mark it (a) Right or (b) Wrong?
I would really appreciate your opinion on this.
Many thanks1
P.S Me and my friend are having an argument about this, he says that this doesn't prove the point at all, while i think the contrary.
I'd say it's long-winded, but correct. The question is "prove this is a homomorphism" and the person... proved it's a homomorphism. That's all that's required. If it was supposed to be a slick proof, it should have been something like "prove this is a homomorphism in five lines or less" (which would be a ridiculous question of course).
This is all assuming that rings aren't required to have a 1 in this context (otherwise it's not a ring homomorphism!)
Great! I know this is long, but for some reason i tend to like long proofs( is this a bad thing by the way??), so right when i saw this problem, i enjoyed proving it in this manner. It looks to me, i don't know how to say, more unconventional, with this i mean a little bit different from the usual standard proofs of homomorphism etc. that's why i wanted to try something different.
Thnx for your reply Office_Shredder.
Proofs that are longer tend to be a little more difficult to follow, so I greatly prefer simple, short proofs. Your proof is completely correct, but I do agree that it's not a very elegant one, primarily because you had to split it up into three cases. To prove the true statement that [tex]\theta \colon \mathbb{Z}_{10} \to \mathbb{Z}_{10}; \theta(\bar m) = 6 \bar m[/tex] is a homomorphism using your method would require handling a lot more cases (I believe the number is 15). However, the proof below works with little modification:
Showing that [tex]\theta[/tex] preserves addition is easy: [tex]\theta(\bar a + \bar b) = 5(\bar a + \bar b) = 5 \bar a + 5 \bar b = \theta(\bar a) + \theta(\bar b)[/tex]. Multiplication is similar, but requires the important observation that 5 is congruent to 52 mod 10: [tex]\theta(\bar a) \theta(\bar b) = (5 \bar a)(5 \bar b) = 25 \bar a \bar b = 5 \bar a \bar b = \theta(\bar a \bar b)[/tex].
edit: I originally missed the second paragraph in your initial post, but a point I'm demonstrating here is that the shorter proof generalizes rather easily, while yours is much more difficult to generalize.
  • · Replies 31 ·
