How does a voltage comparator work? very simple explanation I need
A voltage comparator operates by comparing two input voltages using a standard operational amplifier (op-amp) without negative feedback. When the non-inverting input (V+) exceeds the inverting input (V-), the op-amp outputs its maximum positive voltage. Conversely, if V+ falls below V-, the output switches to its maximum negative voltage. This fundamental behavior is crucial for applications requiring voltage level detection.
  • Understanding of operational amplifiers (op-amps)
  • Basic knowledge of voltage levels and comparisons
  • Familiarity with electronic circuit design
  • Concept of feedback in amplifiers
  • Study the characteristics of operational amplifiers in detail
  • Learn about different types of comparators, including Schmitt triggers
  • Explore practical applications of voltage comparators in circuits
  • Investigate the impact of hysteresis on comparator performance
Electronics students, hobbyists, and engineers interested in understanding voltage comparators and their applications in circuit design.
KAS90
Hello every1..
I would like just sum help in unerstanding how a voltage comparator works..
I tried to read journals.. books.. but till now, I feel so lost..
can someone just give me a simple explanation of the SIMPLEST voltage comparator? sumthing to help me get on with it...
I'd appreciate that a lot..
i will help me with my project, as I'm running out of time..
thanx a lot in advance..
A standard op-amp operating without negative feedback can be used as a comparator. When the non-inverting input (V+) is at a higher voltage than the inverting input (V-), the high gain of the op-amp causes it to output the most positive voltage it can. When the non-inverting input (V+) drops below the inverting input (V-), the op-amp outputs the most negative voltage it can.
http://en.wikipedia.org/wiki/Comparator"
Can't think of any simpler way to say it.
  • · Replies 16 ·
  • · Replies 25 ·
  • · Replies 165 ·
12K
