Distance between two lines in 3D
  • Thread starter Thread starter Melawrghk
    3d Lines
The problem involves finding the shortest distance between two lines in three-dimensional space, defined by their parametric equations. The subject area pertains to vector calculus and geometry in 3D.
  • The original poster attempts to calculate the distance by using the cross product of the directional vectors and projecting the vector between points on the lines onto the unit vector derived from the cross product. Some participants question the correctness of the calculations, particularly regarding the signs in the cross product.
The discussion includes attempts to clarify the calculations involved in the cross product and the projection method. Some participants express uncertainty about the results and seek confirmation or correction of their reasoning.
There appears to be confusion regarding the signs in the calculations, which may affect the results. Participants are also navigating the complexities of vector operations in three dimensions.
Melawrghk
L1=(x,y,z)=(-2,-4,-3)+t(-2,3,-2)
L2=(x,y,z)=(0,0,4)+ s(-2,-3,-1)
Find the shortest distance between the two lines
First, I did the cross product of the two directional vectors from both lines:
(-2,3,-2) x (-2,-3,-1) = (-9,-2, 12)
And its unit vector is:
-9x-2y+12z
2291/2
Then I found the distance between two points on the lines:
R = (0,0,4)-(-2,-4,-3) = (2,4,7)
And then I just tried to project the R onto the unit vector and got 58/sqrt(229), but that's not right. Help?
that should be correct.
EDIT: yeah Dick is right...Sorry about that
I get that the cross product is (-9,+2,+12).
Ooohhh! I see, I'm just retarded and forgot about the negative space in the second row. OOOOH. This all makes sense now!
Thank you!
