Solve Parabola Problem 45: Vertex, Axis of Symmetry, Focus, and Directrix
  • Thread starter Thread starter mustang
    Parabola
The discussion revolves around finding the vertex, axis of symmetry, focus, and directrix of a given parabola defined by the equation x=4y^2 - 6y + 15. Participants are exploring the characteristics of the parabola and the implications of its equation.
  • Participants discuss completing the square to identify the vertex and question the correctness of expressions derived from the original equation. There are hints provided regarding the nature of the directrix and axis of symmetry.
The conversation is active, with participants offering hints and corrections. Some have provided guidance on how to approach finding the focus and directrix, while others are verifying calculations and discussing the implications of their findings.
There is a focus on ensuring the correct application of formulas and methods, with some participants questioning the accuracy of previous calculations and expressions. The discussion reflects a collaborative effort to clarify concepts without reaching a definitive conclusion.
mustang
Find the vertex, axis of symmetry, focus, and directrix of each parabola. Indicate whether the vertex is a max. or min. point.
Problem 45.
x=4y^2 - 6y + 15
Were you able to do the first 44 problems? :smile:
Here is a hint: write x= 4(y2- (3/2)y )+ 15 and then complete the square. That will tell you where the vertex is. Your textbook should have a formula allowing you to find the information you need.
The directrix, in this case, is a vertical line and the axis of symmtry is a horizontal line.
Give it a try and show us what you can do.
This is what I have done:
x=(y2- (3/2)y )+ 15
= 4(y-0.75)^2 +15-.5625
= 4(y-0.75)^2+231/16
Is this right?
Apart from a lacking 4 in your first line (you remember it in the next two lines!), you get the right answer.
1.What is therefore the position of the vertex?
2. How would you approach the problem to determine the directrix and the focus?
Sorry, your expression in 1. is wrong:
You should have:
[tex]x=4(y^{2}- \frac{3}{2}y) + 15 = 4((y-0.75)^2-\frac{9}{16})+15 <br /> =[/tex]
[tex]4(y-0.75)^2+15-\frac{9}{4}=4(y-0.75)^2+\frac{51}{4}[/tex]
Just a few hints about finding the directrix and focus:
The focus lies on the symmetry line y=0.75
Hence, let the coordinates of the focus be [tex](x_{f},0.75)[/tex]
(You must determine [tex]x_{f}[/tex])
The directrix is a vertical line; let it have the coordinates: [tex](x_{d},y),-\infty\leq{y}\leq\infty[/tex]
The parabola is all pairs (x,y) which lies in equal distance from the focus and the directrix:
[tex]\sqrt{(x-x_{d})^{2}+(y-y)^{2}}=\sqrt{(x-x_{f})^{2}+(y-0.75)^{2}}[/tex]
By squaring this equation, and comparing with your original expression, you may determine [tex]x_{f},x_{d}[/tex]
  • · Replies 25 ·
  • · Replies 44 ·
30K
40K
