| Thread Closed |
Moment of Inertia for Infinite Density (mass per area) |
Share Thread |
| Dec3-08, 11:00 PM | #1 |
Suppose you have the density of a disk given by σ=σ0*rn. For n approaches infinity, find the limit of M.I. Interpret your result, which should be physical, reasonable and intuitively clear. 2. Relevant equations Now i found the moment of intertia of the object to be ![]() I am having trouble with the limit though because if I try to do Lo'Hopitals Rule on R^(n+4)/(n+4) it doesnt help and I am not sure if I can use just I = MR^2(n+2)/(n+4) and treat M as a constant but I dont think that would be possible since M is a function of n itself. When i try to figure the limit i get undefined solutions and I am not sure what that means physically. Can someone help please? Thanks, HK |
| Dec3-08, 11:38 PM | #2 |
Recognitions:
Hi Hells_Kitchen,
I = (number) M (length)2 (or perhaps sums of those types of terms). So for purposes of taking the limit of large n, I think you can consider M to be a "given" and find out what happens to the numerical factor in front of the MR2 as n gets larger. |
| Dec3-08, 11:42 PM | #3 |
In that case through Lo'Pitals rule by taking the derivative of lim n --> infinity of
(n+2)/(n+4) = 1. So I = MR^2 right? So that seems like the moment of inertia of a point mass does that mean that if the mass per area of the disk is infinite it will act as if it were a point mass instead of a disk physically speaking? |
| Dec3-08, 11:47 PM | #4 |
Recognitions:
Moment of Inertia for Infinite Density (mass per area)I would think more about comparing this to a thin ring. |
| Dec3-08, 11:57 PM | #5 |
Oh you mean a thin walled hollow ring which has a moment of inertia of MR^2? That does make sense to me as well. So when the mass per area is infinite the disk will act as if its mass was concentrated R distance away uniformally and hollow in the middle.
Thanks a bunch for the help! |
| Dec4-08, 12:12 AM | #6 |
Recognitions:
What I was actually thinking was not that the mass per area is infinite, but about how the density goes as rn. If you plot a series of curves, say r^2, r^7, r^70, etc. over a range from 0->2 (for example), at the very high n values the mass is overwhelmingly located in a smaller and smaller ring at the largest r value. for example at n=2, it looks like: http://img185.imageshack.us/img185/687/r2newor7.jpg at n=7, http://img185.imageshack.us/img185/3636/r7newnx8.jpg and at n=70 http://img185.imageshack.us/img185/852/r70newft7.jpg so it actually effectively becomes a ring for large n (because the inner portions are so much less dense). |
| Thread Closed |
Similar discussions for: Moment of Inertia for Infinite Density (mass per area)
| Moment of inertia & area density | Introductory Physics Homework | 4 | ||
| mass moment of inertia of an irregular area | General Engineering | 2 | ||
| Second Moment of Inertia - Area Moment of Inertia | Classical Physics | 1 | ||
| center of mass, moment of inertia for x = y^2 and y = x - 2 with density d = 3x | Introductory Physics Homework | 2 | ||
| What are moment of inertia, mass moment of inertia, and radius of gyration? | Introductory Physics Homework | 1 | ||
