Center of Mass of a System Problem
The center of mass (CM) of a system consisting of two particles, m1 = 1kg and m2 = 2kg, is calculated using their position vectors at t = 1 second. The position vectors are r1(t) = (txhat - t^2yhat)m and r2(t) = (txhat + t^3yhat)m. The correct formula for the center of mass is given by (m1 * r1 + m2 * r2) / (m1 + m2). After substituting the values, the position of the center of mass is determined to be at (3x, 2y) in the x-y plane, with the velocity and acceleration needing to be derived from the respective derivatives of the position vectors.
  • Understanding of vector calculus
  • Familiarity with Newtonian mechanics
  • Knowledge of derivatives and their applications in physics
  • Basic concepts of center of mass in multi-particle systems
  • Study the derivation of the center of mass for systems with multiple particles
  • Learn about vector differentiation to find velocity and acceleration
  • Explore the implications of center of mass in different inertial frames
  • Investigate the role of mass distribution in determining center of mass
Students in physics, particularly those studying mechanics, as well as educators and anyone interested in understanding the dynamics of multi-particle systems.
catstevens
From an inertial reference frame S, the vector position of a particle of mass
m1 = 1kg is given by r1(t)=(txhat - t^2yhat)m.
The vector position of a particle m2=2m1 is given by r2=(t)=(txhat +t^3yhat)m
Assume t=1second
Find the position, the velocity and the acceleration of the center of mass of the composite system: xCM vCM a CM
m1 x1(1) + m2 x2(1) / m1 + m2
3xkg/ 3kg = 3x-direction
velocity = x
acceleration = 0
I do not think this is right, could some one help?
There is an x and y component to the position vector. You need to take both into consideration.
  • · Replies 25 ·
  • · Replies 16 ·
  • · Replies 17 ·
