Thread Closed
conduction heat transfer mechanisms
Share Thread Thread Tools
Dec8-08, 08:40 AM   #1
[b]1. The problem statement, all variables and given/known data[/b
the ends of a 20cm long,2cm diameter rod are maintained at 0degrees and 100degrees by immersion in an ice-water bath and boiling water. heat is conducted through the rod at 4.5x10^4J/h. of what material is the rod made?
2. Relevant equations
Q/dt=k(A/L)dT
3. The attempt at a solution
i first changed the heat energy conducted into watts which is = J/s
4.5x10^4J/h*1h/60min*1min/60s=12.5J/s
then i found the surface area of the rod
A=2(pi0.01^2)+(2pi0.01)0.2=0.01319m^2
now plug it into Q/dt=k(A/L)dT
12.5=k(0.01319)/0.2(100-0)
k=1.895
with this number i found that the rod is made of ice which has a k value of 1.7 (the closest number) but i checked the back and it suppose to be iron which has a k value of 80.. what did i do wrong?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Dec8-08, 12:56 PM   #2
Recognitions:
Gold Membership Gold Member
Your area is incorrect:
A in this equation is the cross sectional area of the conducting rod... not the entire surface area.
Thread Closed
Thread Tools
Similar Threads for: conduction heat transfer mechanisms
Thread Forum Replies
Heat transfer mechanisms problem; Conduction Introductory Physics Homework 4
Penguin huddling -Heat transfer mechanisms -Radiation problem Introductory Physics Homework 1
Heat-Transfer Mechanisms (HARD) Introductory Physics Homework 2
Heat Transfer (Conduction) problem Introductory Physics Homework 1
Heat Transfer - Conduction Engineering, Comp Sci, & Technology Homework 0
