Register to reply
Moments-calculate centre of mass
by tweety1234
Tags: centre, mass, momentscalculate
Share this thread:
tweety1234
#1
Dec8-08, 04:14 PM
P: 112
A woman and a man support a non-uniform plank, AB of mass 10kg and length 4m. The woman holds the plank 1m from A and the man holds the plank at B. The vertical reaction provided by the woman is 56N find;
A) the vertical reaction force provided my the man
b) The position at which at which the weight of the plank acts measured from A.
2. Relevant equations
3. The attempt at a solution
I worked out the vertical reaction produced by the man which is 42N, but I am really stuck on question 'b' ...
the answer in my book says the center of mass is 2.29m from A,
I have drawn a diagram, can anybody please check it and let me know what's wrong with it?
also my moments equation is..
[tex] 56N \times 1m + 42N \times 4m = 98N (xm-3m) [/tex]
http://www.mathhelpforum.com/math-he...p-untitled.jpg
Phys.Org News Partner Science news on Phys.org
Pilot sites in energy from coffee waste show good results
Startups offer banking for smartphone users
Factor in naked mole rat's cells enhances protein integrity
tiny-tim
#2
Dec8-08, 04:30 PM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,148
Quote Quote by tweety1234 View Post
Hi tweety1234!
That's fine, except I don't understand where the (x-3) comes from
it should be ?
Redbelly98
#3
Dec8-08, 04:31 PM
Mentor
Redbelly98's Avatar
P: 12,070
I can't see your diagram yet, but your description of the problem seems clear enough to respond.
What is "x" in your moment equation?
You seem to be taking moments with respect to end A, which is good. It would make sense to let "x" simply be the distance from A to the center-of-gravity position. But you seem to be defining x as something else.
tweety1234
#4
Dec8-08, 04:36 PM
P: 112
Quote Quote by Redbelly98 View Post
sorry for my unclear post, yes xm is the distance from A to the center of gravity,
but if my equation is correct i still dont get the right answer?
tweety1234
#5
Dec8-08, 04:36 PM
P: 112
should it be x-4 instead? Cause theres 1 meter in between x and A
tiny-tim
#6
Dec8-08, 04:42 PM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,148
No, there's 1 metre in between the woman and A.
x is ?
tweety1234
#7
Dec8-08, 04:43 PM
P: 112
Quote Quote by tiny-tim View Post
Hi tweety1234!
it should be ?
x represents the distance from point A , were the weight of the plank lies. so should it not be x-3 ?
tweety1234
#8
Dec8-08, 04:45 PM
P: 112
x is ?
Okay, now I am a bit confused. Can you show me what the equation should look like ?
thank you!
Redbelly98
#9
Dec8-08, 04:47 PM
Mentor
Redbelly98's Avatar
P: 12,070
If it's x, how can it also be x-3?
Redbelly98
#10
Dec8-08, 04:48 PM
Mentor
Redbelly98's Avatar
P: 12,070
thank you!
You have a force (the weight) acting at a distance x.
Since torque = force times distance, it really is pretty simple.
tweety1234
#11
Dec8-08, 04:51 PM
P: 112
if i want to work out the distance wont i have to minus 3 meters?
Redbelly98
#12
Dec8-08, 04:57 PM
Mentor
Redbelly98's Avatar
P: 12,070
... my moments equation is..
I'm going to have to wait until your attachment is approved, and I can look at the diagram, before commenting further.
tiny-tim
#13
Dec8-08, 05:08 PM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,148
tweety1234, just look at your own diagram (which Redbelly hi Redbelly98! seems to have missed)
between what two points do you think there is a distance of x-3?
General hint: whenever you draw a diagram, give letters to all the points on it, so that you can talk about them later
in this case, call the woman's position W, and the centre of mass C
and then decide what two points you want to measure the distance between.
Register to reply
Related Discussions
Past examination questions: Moments and centre of gravity Introductory Physics Homework 0
Centre of mass vs. centre of gravity Classical Physics 1
HELP : Centre of mass and Centre of gravity Introductory Physics Homework 5
Centre of Mass Advanced Physics Homework 1
Centre of mass - is this right? Introductory Physics Homework 2
