How Do I Calculate Water Flow in Custom-Designed Info Desks?
  • Context: Undergrad
  • Thread starter Thread starter herbicide
    Flow Water
The discussion focuses on calculating water flow for custom-designed info desks shaped as "L" and "U". The water channel dimensions are 250 mm wide and 50 mm deep, with the "L" desk measuring 1800 mm x 1800 mm and the "U" desk measuring 3800 mm x 3800 mm x 2800 mm. A pump with a delivery rate of 440 liters per hour (lph) and a delivery height of 1500 mm is proposed. Key questions include the necessary slope percentage for moderate flow, total water volume required, and pump suitability.
  • Understanding of fluid dynamics principles
  • Knowledge of pump specifications and flow rates
  • Basic geometry for calculating channel dimensions
  • Familiarity with hydraulic slope calculations
  • Research hydraulic slope calculations for effective water flow
  • Calculate the total water volume needed for both desk designs
  • Evaluate pump performance metrics for optimal flow rates
  • Explore fluid dynamics simulations to visualize water flow
Design engineers, fluid mechanics students, and anyone involved in custom water feature installations will benefit from this discussion.
herbicide
Before I start off I wish to make it clear that I am by no means a rocket scientist. This is to say that I don’t have a clue in regards to how to go about this.
Issue at hand: My employer asked me to design 2 bars (info desks) that have a water channel running through the middle of them.
One of the desks take on the form of a “L” the other takes on the from of a “U”. The channel where the water is to flow through is 250 mm wide and 50 mm deep.
The length of the “L” form bar is 1800 mm x 1800 mm.
The length of the “U” form bar is 3800 mm x 3800 mm x 2800 mm.
I pump I plan on using has a delivery rate of 440 lph (liters per hour) with a delivery height of 1500 mm.
My questions:
a) What is the need a percentage of slope that is required to have the water move at moderate flow rate?
b) How much water is required?
c) Am I planning on using the right pump?
I am in dire need of assistance on this; my performance on this particular task will be evaluated and it could end up costing my job.
:smile: Greetings from Germany,
-h
Without a diagram, this is impossible to visualize.
  • · Replies 32 ·
14K
19K
  • · Replies 16 ·
