How should a hunter aim to hit a target? Kinematics problem
A hunter aiming at a target 120 meters away must consider the effects of gravity on the bullet's trajectory. When the bullet exits the gun at a speed of 300 m/s, it will miss the target due to vertical drop. To determine the miss distance, one must calculate the time taken for the bullet to travel horizontally and the corresponding vertical drop during that time. For accurate targeting, the gun should be aimed at an angle θ, which can be calculated by setting up separate equations for horizontal and vertical motion to ensure the bullet returns to the starting height at the target distance.
  • Understanding of kinematic equations for projectile motion
  • Knowledge of horizontal and vertical motion separation
  • Familiarity with the concept of gravitational acceleration (9.81 m/s²)
  • Basic algebra for solving equations
  • Learn how to derive the time of flight for projectile motion
  • Study the effects of gravity on projectile trajectories
  • Explore the derivation of angles for optimal projectile targeting
  • Investigate real-world applications of kinematics in ballistics
Students studying physics, hunters seeking to improve accuracy, and anyone interested in the principles of projectile motion and kinematics.
slayerdeus
A hunter aims directly at a target (on the same level) 120 m away.
(a) If the bullet leaves the gun at a speed of 300 m/s, by how much will it miss the target?
(b) At what angle should the gun be aimed so the target will be hit?
Im havin a little trouble here. I think you are supposed to find how far it goes horizontally. But how can you find this, when you don't know how high they are?
You know how far it travels horizontally. You need to figure out how far it falls (vertically). Figure out the time takes for the bullet to travel that horizontal distance. Then figure out how far it falls in that time.
part b
That was for part a. For part b, set up your equations for horizontal and vertical motion separately. The "trick" is to ensure that the vertical motion comes back to the starting point (y = 0) in exactly the time that the bullet travels the given horizontal distance. Set up the two equations and you can solve for θ.
  • · Replies 17 ·
15K
