Thread Closed
How to measure magnetic field of a magnet
Share Thread
Dec14-08, 03:12 PM   #1
I have a cylindrical neodymium magnet. I know that the magnetic field varies with distance, but how would I determine the magnetic field B at a certain point, through experimentation? I know how to find the force between two magnets at different distances by balancing out with gravity, but I'm stuck as far as measuring fields. Is there an equation which can relate fields and forces for magnets?
PhysOrg.com physics news on PhysOrg.com
>> Is there an invisible tug-of-war behind bad hearts and power outages?
>> Penetrating the quantum nature of magnetism
>> Rethinking the universe: Groundbreaking theory proposed in 1997 suggests a 'multiverse'
Dec14-08, 05:42 PM   #2
Recognitions:
Gold Membership Gold Member
If you want an accurate value you will need to measure the field using e.g. a Hall probe.
Instruments used to measure absolute magnetic field are often called Gaussmeters.
They are however quite expensive.
(a more general name for this type of instruments is magnetometer, although that name can also refer to instruments that measure changes in the magnetic field or relative fields)
Dec14-08, 05:47 PM   #3
Then I guess there's no way to do it economically/creatively? What if MacGuyver only had some duct tape, a paper clip, and a magnet and needed to find out the B?
Mar19-10, 02:50 AM   #4
i know that this replay is too late but i have a solution for this
u can build ur own gauss meter with very law cost
if u wanna know visit this web site
http://www.coolmagnetman.com/magmeter.htm
Thread Closed
Similar Threads for: How to measure magnetic field of a magnet
Thread Forum Replies
How can a permanent magnet produce magnetic field? General Engineering 20
what make the magnet to be magnet with magnetic field? General Physics 23
modeling the magnetic field of multiple magnet bars General Physics 4
What is maximum magnetic field strength of SC magnet General Physics 2
Calculating Magnetic field of permanent magnet Classical Physics 1
