What is the Surface of Revolution with Constant Curvature +1?
The discussion focuses on finding a surface of revolution with a constant Gauss curvature (K) of +1 that is not a sphere. The surface is parametrized using the equation \(\psi (t, \theta ) = ( x(t), y(t) \cos \theta , y(t) \sin \theta )\). The key equation for Gauss curvature is given as \(K = \frac{x' (x'' y' - x' y'')}{y(x'^2 + y'^2)^2}\). The challenge lies in the fact that surfaces of constant Gaussian curvature are locally isometric to spheres, leading to the conclusion that a non-unit-speed curve \(\alpha (t)\) may provide a solution.
  • Understanding of Gaussian curvature and its implications in differential geometry.
  • Familiarity with surface parametrization techniques.
  • Knowledge of the properties of curves, specifically unit-speed curves.
  • Basic proficiency in calculus, particularly derivatives and their applications in geometry.
  • Research the properties of surfaces of constant Gaussian curvature.
  • Explore the implications of non-unit-speed curves in differential geometry.
  • Study the relationship between curvature and surface isometry.
  • Investigate alternative parametrizations for surfaces of revolution.
Mathematics students, particularly those studying differential geometry, as well as researchers interested in the properties of surfaces and curvature.
mooshasta
I'm trying to find a surface of revolution with Gauss curvature K of +1 at all points, which doesn't lie in a sphere.
The surface is parametrized as [itex]\psi (t, \theta ) = ( x(t), y(t) cos \theta , y(t) sin \theta )[/itex]
I have the equation
[tex] K = \frac{x' (x'' y' - x' y'')}{y(x'^2 + y'^2)^2}[/tex]
I am thinking it has to do with the curve [itex]\alpha (t) = (x(t),y(t))[/itex] not having unit speed, but I am kind of stuck as to where to go from there.
Thanks!
Is there one? The only way out I can think of is to make it disconnected. A surface of constant guassian curvature is locally isometric to a sphere.
I know that for a unit-speed [itex]\alpha (t)[/itex], the equation reduces to [itex]K = \frac{-y''}{y}[/itex], which does clearly represent a sphere.
The way the question is worded on my homework seems to point to the fact that that reduction only applies to unit-speed curves, which is why I think that perhaps an [itex]\alpha (t)[/itex] that doesn't have unit-speed perhaps can give a surface of revolution with constant curvature +1 that isn't a sphere... but maybe there's another "gimmick" that I'm overlooking...
Anyways, thanks for your help!
