Coordinate Transformations in GR
The discussion revolves around the significance of coordinate transformations in General Relativity (GR). Participants explore the theoretical implications, practical applications, and conceptual understanding of these transformations within the framework of GR.
  • Some participants propose that coordinate transformations are crucial due to the principle of relativity and the general covariance of GR equations, suggesting that the laws of physics should remain consistent across different reference frames.
  • Others argue that coordinate transformations provide a straightforward way to visualize different reference frames.
  • A participant notes that in GR, the interaction of gravitational mass leads to nonlinear equations, complicating the establishment of independent coordinate systems.
  • Another point raised is that GR allows for scenarios where a single coordinate choice cannot adequately describe all events, necessitating the use of transformations.
  • A later reply emphasizes that the essence of relativity is about how different observers measure the same events, linking this to the prevalence of coordinate transformations in GR.
  • It is mentioned that the transition from Special Relativity to General Relativity involves a shift from preferred coordinate systems to arbitrary ones, highlighting the importance of understanding transformations.
Participants generally agree on the importance of coordinate transformations in GR, but multiple competing views on their implications and applications remain. The discussion does not reach a consensus on the best way to conceptualize these transformations.
Some limitations include the dependence on specific definitions of reference frames and the unresolved complexities of nonlinear interactions in GR. The discussion also reflects varying levels of familiarity with the mathematical underpinnings of the concepts.
This discussion may be of interest to those studying General Relativity, particularly students and enthusiasts seeking to understand the role of coordinate systems and transformations in the theory.
Mad Dog
As I try to understand GR, I find coordinate transformations just about everywhere. My question is simply: What is the reason coordinate transformations play such an important role in GR? Thanks.
I'd say the reason is that one of the most important aspects of GR is the principle of relativity and the general covariance of its equations. Basically, that the laws of physics should be the same in any reference frame so naturally you'll want to perform coordinate trasnformations.
That and also coordinate transformation is the simplest (read: best) way to visualize reference frames.
In special relativity, you can can use 3 spatially orthogonal plane wave solutions of Maxwell's "free space" equations as rulers for 3 orthogonal spatial axes. The 3 rulers won't interact with each other and Maxwell's equations are linear. In general relativity, each plane wave has energy or "gravitational mass" and should attract the other plane waves, so Maxwell's "free space" equations should become nonlinear indicating that you cannot get independent plane wave solutions. This will be true of any rulers you set up, so you will have no orthogonal coordinates, except very locally. The bending of your rulers and clocks or "metric" appears as spacetime curvature.
Another reason is that GR permits solutions in which it is mathematically impossible for a single choice of coordinates to fully suffice at every event.
I'm replying here to my own question, as a contribution to the Forum:
Even after having received the answers to my question, I continued to be concerned, and finally realized the answer is simple and obvious:
The name of the field is "Relativity" and the key is right there - we're talking about how different observers will measure the same events. Different observer's points of view are expressed as observations from different reference frames, and "reference frames" is simply another way of saying "coordinate systems," so of course coordinate transformations are found everywhere in General Relativity.
The second reason is that:
-For generations whe have dealt with coordinate translations, rotations, and moving coordinate systems without thinking much about it.
-In Special Relativity we add the Lorentz Transformation (and have to think a good bit about that).
-One of the basic lessons of General Relativity is that there are no preferred coordinate systems, so now we must deal with arbitrary coordinate systems and their transformations, and learning to do this is an essential part of GR.
  • · Replies 40 ·
  • · Replies 37 ·
  • · Replies 22 ·
  • · Replies 22 ·
