Calculus Work Problem (Spherical Water Tower)
The discussion focuses on calculating the work done in filling a spherical water tower with a diameter of 40 ft and a center height of 120 ft. The work is determined using the formula dW = (dV)*(density)*(displacement), where the density of water is 62.4 lb/ft³. Participants clarify the use of variables, specifically the need to express the radius in terms of height, and the correct limits for integration when calculating work for both half-full and entirely full scenarios.
  • Understanding of calculus concepts, specifically integration.
  • Familiarity with the physical concept of work in physics.
  • Knowledge of geometric properties of spheres and cylinders.
  • Ability to manipulate variables in equations, particularly in relation to volume and displacement.
  • Study the derivation of the volume of a cylindrical section of a sphere.
  • Learn about the application of integration in calculating work done in physics problems.
  • Explore the relationship between radius and height in spherical coordinates.
  • Practice similar problems involving work calculations for different shapes and densities.
Students studying calculus, physics enthusiasts, and anyone involved in engineering or architectural design requiring work calculations for fluid dynamics.
dbai
A spherical water tower 40 ft in diameter has its center 120 ft above the ground. That means, there is a 120 ft pole connected to the 40 ft diameter spherical tank. Water is being pumped at the ground level to fill the tank with water of density 62.4 lb/ft3,
a) How much work is done in filling the tank half full?
b) How much work is done in filling the tank ENTIRELY full?
  • I calculated that dV would be a cylindrical section of the tank with height dy --> πx2 dy
  • Density is given 62.4 lb/ft3
  • I used (120 - y) as my displacement
    ∫(Pi)x2(120 - y) dy Limits: 0-120 ??
    I don't know if the displacement is correct and how to convert x in terms of y.
I am not sure what it is are using x for? Do you mean r?
What is x supposed to be here? You should draw a picture of a right-angle triangle whose L-shape rests upright on the infinitesimal cylindrical slice of water. Then the hypotenuse would be constant, namely 20^2. Denote the base by x (or r) and the height as 20-y. See how to take to it from here?
10K
