Solving Sn-Pb Phase Diagram Questions
The discussion revolves around solving questions related to the lead-tin (Sn-Pb) phase diagram, specifically concerning the melting behavior of a lead-tin alloy with a composition of 30 wt% Sn and 70 wt% Pb. Participants explore the temperatures at which the first liquid phase forms, the composition of that liquid phase, the temperature of complete melting, and the composition of the last solid remaining prior to complete melting.
  • Homework-related
  • One participant suggests that the first liquid phase forms at 183°C and the composition of this liquid phase is 61.9 wt% Sn.
  • Another participant agrees with the initial answers but expresses uncertainty about the interpretation of the composition of the liquid phase, questioning whether it refers to the components in the liquid or the overall alloy composition.
  • A participant mentions that the complete melting of the alloy occurs around 250°C and that the last solid remaining prior to complete melting has a composition of 15 wt% Sn.
  • Some participants discuss the need for a phase diagram to assist in solving the problem, indicating that access to such diagrams may be problematic.
  • There is a clarification about the interpretation of the question regarding the composition of the liquid phase, with one participant asserting that the question specifically asks for the composition of the liquid phase rather than the total alloy composition.
  • Another participant provides guidance on using the lever rule to determine the amount of liquid at a given temperature if that were to be asked.
Participants generally agree on the temperatures and compositions suggested, but there remains some uncertainty regarding the interpretation of the composition of the liquid phase and how it relates to the total alloy. The discussion does not reach a consensus on these interpretations.
Some participants express confusion about the definitions and interpretations of terms related to the phase diagram, indicating that there may be missing assumptions or varying definitions that affect the discussion.
soul
Hi everyone,
A lead–tin alloy of composition 30 wt% Sn–70 wt% Pb is slowly heated from a temperature
of 150 C (300F).
(a) At what temperature does the first liquid phase form?
(b) What is the composition of this liquid phase?
(c) At what temperature does complete melting of the alloy occur?
(d) What is the composition of the last solid remaining prior to complete melting?
It is probably an easy question, but I thought it is a good idea to consult first.
a) At 183 C, the first liquid phase forms.
b) We can draw a tie line and the point intersects with the liquidus line, gives us the composition of liquid. It is 61.9 wt % Sn.
c) It is around 250 C. Because phase diagram is on liquidus line.
d) Composition is 15wt % Sn. We can find it by drawing a tie line.
I am not sure about the question b and d. Because as far as I know composition of this liquid means that the composition of the components in this liquid. For instance, in some specific temperature liquid is composed of 30wt % Sn - 70 wt & Pb. However, in some sources I saw that they interpreted this statement as the composition of liquid phase in the total alloy. Like, again in some temperature, 30 % liquid- 70 % solid. Which one is correct. I am a bit confused. Any help will be greatly appreciated.
Thank you.
Hard to help without having phase diagram at hand.
I have put it below the heading of "relevant equations", but I guess there is a problem about seeing it so I attached it to the problem. Thanks for your warning.
I can see it now, could be that was my internet playing its dirty tricks, I have serious problems with web access lately.
I think you are right, but I have not analyzed phase diagrams for eons, so second opinion won't hurt.
Your answers look good to me.
I think you interpreted it fine, since the question asked for the composition of the liquid phase, not the amount of liquid in the total system.
ternary Zr-Nb-Y
Please help me do you have ternary phase diagram of Zr-Nb-Y
alloy.
thanks in advance
what is the structural difference between eutectic & proeutectic alpha?
your answers of question b&d are absolutely correct..if you want to know the composition in liq. then draw tie line at given temperature , where the tie line cuts the liqidus line drop a vertical line where it cut the x-axis is the correct composition (61.9 wt% sn)...
but if it is asked that what is the amount of liquid at a given temp. & for an particular alloy then u have to use the lever rule...
9K
