Equivalence Principle & Tidal Effects
The discussion revolves around the Equivalence Principle and its implications, particularly regarding tidal effects in gravitational fields versus accelerated frames. Participants explore theoretical aspects, historical context, and the nuances of different formulations of the principle.
  • Some participants assert that the Equivalence Principle suggests one cannot distinguish between gravitational force and acceleration in a closed room, but question whether tidal effects can be measured in a gravitational field.
  • Others argue that tidal effects arise from the non-uniformity of a gravitational field, which is not present in a uniformly accelerated frame.
  • A participant mentions that the Equivalence Principle can hold in curved spacetime when measurements are taken in sufficiently small regions, suggesting that tidal forces approach zero in such limits.
  • There is a discussion about the different formulations of the Equivalence Principle, with some participants noting that distinctions can be subtle and not immediately evident.
  • Some participants question whether Einstein's predictions, such as the bending of light, are valid only in uniform gravitational fields, raising concerns about the implications of the Equivalence Principle in curved spacetime.
  • A participant references previous discussions on the topic, indicating that defining the Equivalence Principle is complex and varies across different contexts.
Participants express a range of viewpoints regarding the Equivalence Principle and its implications, indicating that multiple competing views remain. There is no consensus on the validity of the principle in non-uniform fields or its application in curved spacetime.
Limitations include the dependence on definitions of the Equivalence Principle, the subtleties in its formulations, and the unresolved nature of how it applies to tidal effects and light bending in varying gravitational contexts.
patrickd
It is my understanding that the Equivalence Principle postulates that if I were standing in a closed room, I would not be able to distinguish whether the downward force that I felt was caused by (1) the presence of a massive body such as the Earth exerting a downward gravitational force or (2) the upwards acceleration of the entire room. Would I not in principle be able to measure a tidal effect (slightly less downward force measured at the ceiling than at the floor) in the gravitational case that would not be present in the acceleration case?
I don't think know if it's possible to produce a uniform gravitational field by acceleration. The most common accelerated observer is the Rindler mouse, but it doesn't experience a uniform gravitational field.
Nonetheless, tidal effects do go beyond the equivalence principle. Some ways to think of the EP are that in Newtonian gravity, an accelerating free falling accelerometer will read zero. Hence we should redefine acceleration to be what an accelerometer reads. This leads to the Newton-Cartan formulation of Newtonian gravity as curved spacetime. From this point of view, Einsteinian gravity is a reworking of Newton-Cartan gravity to include special relativity. (Historically Einstein discovered GR first, and inspired Cartan's reworking of Newton.) In GR, the EP is the statement that (i) at every point in spacetime we can set up coordinates so that the metric is exactly flat at the origin, and deviates from flatness away from the origin at second order or more in Taylor series (ii) the laws of physics take the same form at the origin as in flat spacetime. In GR (i) is always true, but (ii) is true only for "first derivative" laws such as Maxwell's equations in GR, but it is not generally true for "second derivative" consequences which can detect spacetime curvature or tidal effects at an event. Ohanian's textbook, and Carroll's and Blandford and Thorne's online texts have more discussion of this.
The simple answer is that the equivalence principle equates acceleration of the "room" with a uniform gravitational field. Tidal effects are due to non-uniformity of a gravitational field.
Al
Can't we also say that the equivalence principle holds in curved spacetime when you take the limit as the size of your "room" (and the time interval in which you are making your measurements) approaches zero, and that in this limit the tidal forces measurable in this patch of spacetime approach zero as well?
Perhaps related: is a non-zero second derivative local or nonlocal? It is local in the sense that it is a well-defined limit at every point. It is non-local in the sense that a derivative, and even more so a second derivative, always involves taking a difference in space or time.
The reason Einstein was so happy when he found the "Equivalence Principle", because its predicting power. He used it to predict that light must fall/bend in gravitational field, since he deduced that light must bend in an accelerating elevator
True, tidal effect would not be present in the acceleration case. But can you use tidal effect to invalidate Einstein's prediction of light bending? If not, then Equivalence Principle still hold regardless of tidal effect
There are a number of different formulations of the "equivalence principle (EP)" with slightly different implications. Wikipedia discusses some. Post #3 here reflects Einstein's version, I believe.
The distinctions can be subtle and are not self evident to me. Peter Bergmann, a student of Einstein's writes in one definition of EP (THE RIDDLE OF GRAVITATION):
An alternative formulation (of EP) is based directly on the equal gravitational acceleration of all objects in the same gravitational field...This formulation (of EP) must be qualified; inertial and gravitational accelerations may be distinguished from each other in that a purely inertial effect can be eliminated by adopting an inertial frame of reference.
So equivalence principle only work in uniform gravitational field? Einstein's prediction of bending of light beam deduced from equivalence principle. Is it valid only in uniform gravitational field too?
I recommend reading through this thread from December, apparently defining the equivalence principle is fairly subtle and there are a few different definitions which apply to different cases.
Totally Useless, waste of my time and yours
If you say so. But unless you think the info on that thread is wrong, then you see that your question about how the equivalence principle works in curved spacetime has no simple answer. For instance, in post #34 on p. 3 of that thread atyy gives two mathematical ways of defining the equivalence principle in curved spacetime:
There is a "mathematical" equivalence principle stated from within GR that (i) in curved Lorentzian spacetime at any point (or sufficiently close) one may set up a coordinate system in which the metric is exactly flat Lorentzian at the point, and deviates from flatness away from that point only at or above second order in Taylor series (ii) the known fundamental laws of physics (Maxwell's equations), but possibly not the derived laws involving second derivatives, in curved Lorentzian spacetime at that point have the same form as those in flat Lorentzian spacetime.
atyy also started another thread more focused on definitions of the equivalence principle here. The main subtlety seems to be the issue of the principle only working locally up to the first-order terms in the Taylor (no second or higher derivatives)--if those higher-order derivatives are taken into account, then apparently GR can't even be said to reduce to SR locally.
feynmann asks:
If you are referring to Einsteins original insight, I think the general answer is "yes"...but (a) I am unsure just how far Einstein carried that "equivalence" and (b) there are now so many definitions of EP that inferences vary from definition to definition...
Einstein found enough of a link between acceleration and gravity to make a selection from among different formulations for GR. But it would be wrong to conclude that acceleration and gravity are equal in every respect: Peter Bergmann, a student of Einsteins, says in THE RIDDLE OF GRAVITATION, (page 9)
..the principle of equivalence...has a historical significance in that gravitational and inertial effects are to some extent equivalent. But it is safer today to let the term principle of equivalence denote only the equality of mass as a measure of (a) body's acceleration and of mass as a source of gravitational attraction"
(I'm unsure exactly what the distinction is!)
But apparently a distinction between acceleration and gravity can (maybe) be made via the Unruh Effect, of which Wikipedia says:
The Unruh effect, discovered in 1976 by Bill Unruh of the University of British Columbia, is the prediction that an accelerating observer will observe black-body radiation where an inertial observer would observe none. In other words, the background appears to be warm from an accelerating reference frame.
In turn, this is explained via an apparent event horizon which forms for all accelerating observers. I don't believe it has been experimentally verified.
And Jesse posts:
I have not looked at all the math involved, but this has been a point I have also seen elsewhere. Part of the issue is how closely you take a portion of curved space to be "flat"...in the simple case of acceleration versus free fall in an elevator, it makes little difference. If you drop two balls separated by a distance and ask "do they come together as they fall" the whole focus is different.
I have read elsewhere that Einstein chose a formulation of GR that reduces to SR without gravity...which implies he had considered other formulations that did not so simplify.
atyy posts:
That's also my understanding, if I understand the statement correctly, but via explanations from others rather than first hand mathematical analysis.
In another thread, DrGreg explained there is an "observed" curvature of spacetime relative to an accelerating observer...this is what I have read elsewhere but precisely how it relates to equivalence and gravitational curvature is not clear to me. For the time being I am taking them to be similar but distinct phenomena.
The derivative is the limit of a difference. Any derivative is purely local.
glad to see that expressly made! I thought maybe I was missing something...and ditto for subsequent derivatives!
That's true, but in the case of knowing all the infinite higher-order derivatives of a function at a point, you can use the Taylor series to get "nonlocal" information about the exact shape of the function out to some finite distance (the radius of convergence, which may be infinite)...is there anything analogous in GR? Is there any quantity where a local observer could in principle measure an infinite number of nonzero higher-order derivatives of that quantity, and use this to determine the curvature of spacetime out to some finite (or infinite) distance?
I was thinking along the lines of Blandford and Thorne's discssion "What is the minimum amount of nonlocality that can produce curvature-coupling modi cations in physical laws?", Chapter 24, p24 http://www.pma.caltech.edu/Courses/ph136/yr2006/text.html
It would help if you gave a link to any other thread you mention. In my (relatively) old age I can't remember everything I ever said in every thread!
It is true that an accelerating observer (in a Born-rigid rocket in the absence of gravity -- the "Rindler mouse" that atyy refers to) will see a number of effects that a "stationary" observer would see near a black hole e.g. an event horizon and (pseudo-)"gravitational" time dilation. But I would not describe these effects as "curvature of spacetime". Spacetime curvature is, loosely speaking, another name for tidal effects, and occurs only with a "real" gravitational source.
Suck it up, DrGreg!
I can't remember all the threads I respond to!
I link when I remember threads and find them...
So equivalence principle only work in uniform gravitational field? Is Einstein's prediction of bending of light beam deduced from equivalence principle only valid in uniform gravitational field?
If you know the answer, why don't you spell it out for us?
>>> Please do Not recommend any reading, just answer the question and to the point
Yes and No. The equivalence principle is exactly correct only for a uniform gravitational field. And approximately correct for an approximately uniform G- field.
I see. I think it's impossible that Einstein did not know non-uniform gravitational field. It's his great genius to make thing simple and deduce the fundamental truth of nature. Similar, Newton found out in order to formulate his law of mechanics, he need to ignore the friction force that we encounter everyday. In my opinion, all the talking of tidal effects is non-essential and Einstein must know about them when he proposed the equivalence principle
I am not an expert in this but isn't it so that something like tidal effect is present in Rindler coordinates too e.g. front of the body is accelerating a bit less than it's back?
It's true that front of the body is accelerating a bit less than it's back.
I think it's similar to say that the Sun is not perfectly round, but Newtonian gravity still apply.
That's how science works, otherwise it's impossible to make progress
There is no theory that is 100% correct, even GR has been verified to 10^-5
It's not really like that--the fact that different parts of a body must have different proper accelerations in Born rigid acceleration is a purely theoretical result, with "Born rigid acceleration" referring to the condition that the distance between observers sitting on different points on the accelerating object should remain constant in their own instantaneous inertial rest frames from one moment to another (since they are accelerating, they have different inertial rest frames at different moments). See this page for example:
We can imagine a flotilla of spaceships, each remaining at a fixed value of s by accelerating at 1/s. In principle, these ships could be physically connected together by ladders, allowing passengers to move between them. Although each ship would have a different proper acceleration, the spacing between them would remain constant as far as each of them was concerned.
Since clocks at different points on the accelerating object would experience different proper accelerations, some clocks would seem to be ticking faster than others in a coordinate system where the accelerating object was at rest (Rindler coordinates), and it's my understanding that this time dilation factor is actually equivalent to the gravitational time dilation between clocks at different heights in a small room in a gravitational field--see pervect's post #75 on this thread.
Of course he did. That is why he qualified things with the word "local", for example (Einstein equivalence principle) "The outcome of any local non-gravitational experiment in a laboratory moving in an inertial frame of reference is independent of the velocity of the laboratory, or its location in spacetime." and (strong equivalence principle) "The outcome of any local experiment, whether gravitational or not, in a laboratory moving in an inertial frame of reference is independent of the velocity of the laboratory, or its location in spacetime."
Einstein Online has a good discussion on this very topic at http://www.einstein-online.info/en/spotlights/equivalence_principle/index.html .
  • · Replies 44 ·
  • · Replies 36 ·
  • · Replies 36 ·
  • · Replies 24 ·
