Are there any accidental things in Physics?
  • Context: High School
  • Thread starter Thread starter fernando_close_minde
    Physics
The discussion revolves around the concept of whether accidental events exist in physics, exploring the implications of determinism, probability, and chaos theory. Participants examine the nature of causality and randomness in physical phenomena, touching on quantum mechanics and the predictability of systems.
  • Some participants argue that everything in physics has a cause, suggesting that probability is a reflection of our inability to measure all influencing factors rather than true randomness.
  • Others propose that quantum mechanics introduces fundamental probabilistic elements, implying that accidents can occur at a quantum level.
  • Chaos theory is mentioned as a framework where small changes in initial conditions can lead to unpredictable outcomes, complicating the notion of determinism.
  • One participant emphasizes that physics relies on mathematical models that often assume ideal conditions, which may not account for all real-world complexities.
  • Definitions of "accident" vary, with some participants seeking clarification on what constitutes an unpredictable event in physics.
  • There is a discussion about the philosophical implications of labeling events as "accidental" versus "causal," with some expressing discomfort with the terminology.
Participants do not reach a consensus on whether accidental events exist in physics. While some support the idea that quantum mechanics allows for randomness, others maintain that all events are ultimately determined by prior causes.
Participants express differing views on the definitions of accidents and randomness, leading to ambiguity in the discussion. The conversation reflects a range of philosophical perspectives on determinism and the nature of physical laws.
Are there any accidental things in physical?
  • Yes
    Votes: 8 66.7%
  • No
    Votes: 3 25.0%
  • What??
    Votes: 1 8.3%
  • Total voters
Hi there
My question is, are there any accidental things in physical ?
Why am I asking this question?
Many people think the whole universe is either created or it's made by chance! to me it sounds like probability and chance are just matematical ideas and we don't have anything accidental in the real world nor in any area of physics, or at least we shouldn't.
I think anything that happens has a cause and something that has a cause can't be accidental.
For example in math we can calculate if we throw a dice once, the chance that the dice shows 1 is 1/6.
But in physics if know exactly how much the dice weights and how exactly it is thrown and what forces are effecting it and if we can measure them then we can predict what number will it be showing.
So generally we use probability because we are not able to measure some quantities.
One of the conclusions from Newton's rules is that if someday we know how much does each thing weight and how it is moving and etc.. we can predict everything that will happen in future.
What do you think? Is there anything accidental that is reviewed in any area of Physics?
Well, first, if you believe in QM then you should accept that at a fundamental level accidents do happen because at that level everything is determined probabilistically.
But even if we were to live in a fully deterministic world, chaos theory and "complexity" tell us that often we must have perfect knowledge of a system in order to make any predictions about it. So the question of whether or not you could in principle predict everything becomes somewhat academic as you will probably never obtain the knowledge required to make these predictions.
Matt
I don't think so. Because physics is based on math models, and its theory has been created to explain the things as far as mathematics can do. Any physics student realizes that all of the problems we do are supposing things such as: constant gravity, constant pressure, ideal gases, no friction...
That's the point. Using math models we can learn about universe and explain so many things that happens on it. Certainly there are a lot of things that can be explained but we can't write down a equation to solve it.
You can understand the meaning of "aceleration" and see a car acelerating without consider friction, the air, and so, and so, and so...
Chemist can't do that :)
Oh, I forgot to say that I answered "No" to the question above.
Thanks for your replies :)
If you believe that the answer is 'yes' and there are accidental things happening on random basis in the physical world I would really appreciate if you give a clear example of a physical accident.
Hmm this is difficult as I'm not sure what you define as an 'accident'. By your first post it sounded like you defined one as 'something you could not predict', but now I'm not so sure.
Perhaps before we continue you could give us your definition?
Matt
Nothing is made by chance
Anyone who thinks that everything happens or accidents take place by chance is totally wrong. It is foolish to think this. Every thing happens for a reason. There r scientific reasons for every thing which happens. Ok think about some time, if the humans or the universe were created by chance, then how come they have so complicated structure and mechanism.
There are two branches of physics that apply here. Of course quantum theory has its well known uncertainty and probability aspects, and chaos theory has the sensitive dependence on initial conditions ("butterfly effect") where small deviations can expand exponentially into large ones. The bottom line is that physics does not say you can predict the future exactly; it says if you could have perfect knowledge you might do so.
In practice our gross physical world seems pretty deterministic, but that seeming can't be pushed too far. Every day we are buffeted by winds that can't in principle be forecasted too many days into the future.
And in QM, the output of two quantum systems set up in exactly the same way will follow the same probability distributions, but the individual outcomes will not be the same. They are "accidental" within the limits set by the distribution function.
I think that staements to strong, can you cannot say that there's DEFINTELY a reason that a wavefunction we collapse into a particular eigenstate as opposed to another eigenstate.
The problem is that we can't ever know the exact position and speed of a particle at a point in time... so we'll never really know the answer, eh? (Or maybe that's the answer itself...)
I personnaly believe that, yes, causality applies and everything in the future is pretty well determined by the present. But: We can't even understand the present, so good luck with the future.
It seems the majority of responders here take view that QM provides the answer that physics does have accidental components, though I'm not sure philosophically if "accidental" is the same thing as "acausal." I agree that QM means the universe is not strictly deterministic, and that een if we had complete information of initial conditions, the future would not be entirely predictable (more predictable for the very short term in near neighborhoods, and less predictable as time and distance increases).
I don't like the term "acidental," bcause it's opposite seems to be "intentional," and that opens up aspects of theology that are outside the scope of physics.
What I meant by accident is an event that happenes in a disordered way. something that is abseloutly random and there is no possible way to predict it. Anything that happens by chance. An unplanned event, unexpected and undesigned, which occurs suddenly and at a definite place and a lot of other good definitions that you can browse trough http://www.google.com/search?hl=en&lr=&ie=UTF-8&q=define:accident
I think in some branches of physics because we are not able to measure some quantities accuartily (or we don't believe those quantities are measureable) we use probability rules to solve the problems, and using these rules DOES NOT mean that there are things that happen in physics on RANDOM basis. Does anyone disagree with that?
I believe the very popular idea that the whole universe is either created or happened accidentally is a fallacy entitled "False Dilemma" in logic, and that means these two are not the only two options, more than that I believe not only these two are not the only options but in fact these are two WRONG options to explain the existence of the universe.
The second option has less to do with science, I am just very curious to know if there are areas in physics in which things happen in an unpredictable way?
Theists insist to persuade people that atheists believe the universe is created just by chance, we know although the probability of everything being created by chance is a very very small number but that doesn't make it IMPOSSIBLE at all,but More than that what I'm trying to ask from you guys is that is the first option "being created by chance" a physically approved argument? Do we categorize events as either predictable or accidental in physical sense? I didn't think so...
We were discussing these terms with some theists and they have claimed that there are areas in physics that accidents happens and we have to use probability rules, they named "spectroscopy" and "statistical thermodynamics" as two examples and I'm trying to validate my idea that "that we use probability rules (if really use), that doesn't mean some events happen in physics just accidentally"
That's right, maybe acausal is a better word for this question.
Who's to say we will ever be able to have quantum systems that are "set up in exactly the same way"? If the two systems are said to be completely equvialent, it implies one actually checked each and every component and verified that all of its properties match on both systems. And if one were to perform this operation on two quantum systems their results would no longer be different.
Right?
Let's not confuse our inability to predict the future and the future being 'accidental'. We also can't predict the weather with great accuracy, does that mean it behaves in a completely random way? No, it just means it is too complicated to be predicted efficiently.
I don't like to think the future can't be predicted even if we had unlimited computation power and complete information over the inital setup. After all, that's what the universe does all the time - it predicts the future and manifests it. However, it only predicts the 'immediate future', i.e the state of afairs around the universe at the moment that will follow the present. It might not be possible to predict the long term future, without going through every step in between. Which is why I believe we will never be able to predict the far future... (And no, I'm not talking about some divine being here. Think of it like a giant uber computer. :smile:)
Well, I read in a book, that the CHANCE of the big bang happening would be the same as if you got 1 million blind men, put them all in a row, and gave them rubix's cubes and fi they were to solve them all at the same time.
Even if that's true (I never heard of anything remotely close to that :smile:), we shouldn't be so surprised. It's similar to the question raised in this thread:
https://www.physicsforums.com/showthread.php?t=18905
billy_boy_999 asks how come there so many objects in orbits in nature. HallsofIvy says while there are many objects in orbits, there are a lot more objects which didn't go into orbit so we don't see them today. Similarly, you may find it amazing that the big bang occurred having a chance of only one in a million, but it's not that amazing when you consider the fact that if it hadn't occurred, we wouldn't be here to discuss its probabilities. :smile:
You know, a funny thing is that I thought about that before I was told it.
Whenever I would see someone arguing about creationism on tv (or in a book) and how the chances were so low for it to happen HERE etc etc etc I would think: "Well, does it really matter if it's here? There's so many places it could be, and we're only going to ask in the places where it happens... so maybe here is somewhere else."
Then I read "A Brief History of Time" and learned that this was the anthropic (sp?) principle.
Pretty neat on my end.
Are we not men?!
I'm surprised that nobody seems to have mentioned even the possibility of human free will (although God came up).
I think "chance" and "accidental" are human concepts which are unlikely to apply to fundamental "reality" (which may well be just another concept). "Acausal" is better, but even this idea... I mean, what if we accept the idea of a vacuum really being some kind of quantum soup, with particles and anti-particles popping into being with (apparent) randomness. This general process is a property of the vacuum, but each discrete event -- if it IS discrete -- doesn't seem like it could possibly have any cause.
Also, isn't the very nature of quantum mechanics dependent on the idea that everything happens in discrete units -- analogous to a dripping faucet, but with no way to know precisely when the next drop will fall? Since we have no possible access past the quantum barrier, we can never know whether there's some explanation why Quantum Droplot #1 fell at 12:33:16:05 and #2 fell at 16:06 but #3 didn't fall until 16:08. To use a real example, isn't radioactive decay fundamentally unpredictable? Regardless, there's no question that the future is intrinsicly unpredictable, as previously explained, essentially because of the Butterfly Effect... as well as the fact you'd need a computer bigger than the universe to do the predicting, even if it were possible.
For me, there are two big questions relevant to this topic. First, was it inevitable that the Big Bang would result in the existing laws of physics, and, either way, what was the mechanism by which they came into being? Is there one primordial variable... or constant? And forget the anthropic principle -- I can understand how it's conceivable that anything exists. (It's equally inconceivable that nothing could exist.)
Secondly, can we ever know whether consciousness and subjectivity are inextricably entangled with being, and whether it's meaningful to speak of possible aspects of being which are in no way accessible to minds like ours, at least not via just five senses. Just a blind man could never have a qualitative experience of blue, are there "colors" in the universe which humans will never experience or even be able to measure? "If an ear makes a tree, and there is no sound there to fall, does it hear a forest?" (as an enlightened Zen Master observed after his stroke).
This is really a very old debate. The idea of "acausality" goes back to the 16th (15th?) century with the philospher Duns Scotis. His idea of things happening without cause was so radical. As is often the case, when people don't like an idea, they can take the easy way out and say "anyone who thinks this is a fool." The word "dunce" is named after him.
But the notion of causality/acausality caught on. Who can say that a single event was caused by one other single event? "cause and effect" has been relegated to the realm of illusion for centuries now. Modern physics and metaphysics have already gone past the argument of "causality" and are more into the word "deterministic."
In the modern world we have both chaotic systems AND quantum dynamics. CAn we predict the weather? If all events are due to "cause and effect," then it would be a matter of time before we get a fast enough computer and put in enough data that is "perfectly precise."
But quantum rules say we can never get to the "perfect" level of prediction. This means that randomness and probability are constantly entering the equation.
I voted "yes" to accidental (according to its modified definition). All the time.
QM is often portrayed as being limited by our technology, ie we can't measure position and velocity exactly but if we could... No. Its more fundamental than that. A particle simply doesn't have both an exact position and velocity. Given a binary choice in QM, it really is impossible to predict which outcome will happen.
  • · Replies 32 ·
  • · Replies 52 ·
  • · Replies 42 ·
  • · Replies 102 ·
11K
  • · Replies 41 ·
