Projectile motion (ball thrown horizontally)
The problem involves projectile motion, specifically a ball thrown horizontally from a height of 16.01 meters, which impacts the ground with a final speed that is five times its initial speed. Participants are exploring the relationships between the initial and final velocities, as well as the time of flight and the effects of gravity on the motion.
  • Participants discuss the components of velocity, noting that the initial vertical component is zero since the ball is thrown horizontally. They explore equations relating to the final vertical velocity and the effects of gravity. There are attempts to solve for the initial speed using kinematic equations, and some participants express confusion about their calculations and the correctness of their answers.
The discussion is ongoing, with participants attempting to clarify their understanding of the problem and the equations involved. Some guidance has been offered regarding the use of components and the Pythagorean theorem, but there is no explicit consensus on the correct approach or final answer yet.
Participants are working under the constraints of a homework assignment, which may impose specific requirements for problem-solving and presentation of answers. There is a noted confusion regarding the interpretation of components of velocity and the application of kinematic equations.
boomer77
a ball is thrown horizontally from a height of 16.01m and hits the groung with a speed that is 5.0 times its initial speed. what was the initial speed?
dx=?
vx=?
t=?
dy= -16.01m (because the ball is falling that distance)
viy= vi
vfy= 5vi
a= -9.8 m/s^2
vf^2= vi^2 + 2ad
(5vi)^2= vi^2+ 2(-9.8)(-16.01)
25 (vi^2)= vi^2+ 313.8
what should i do next if this is right?
In the y direction, (Vy)i=0 because it was thrown horizontally. So it only had an initial horizontal component of velocity.
When it lands, it has both a horizontal and vertical component of velocity.
Now, with that in mind, can you see an equation that will let you find the final y-component of velocity?
Hint: you have dy, ay and (Vy)i.
i am following you so far
so my work will now look like
(5vi)^2=0^2+2(-9.8)(-16.01)
25(vi^2)=313.796
divided by 25
vi^2=12.55
vi=3.54
i plugged this into my problem set and it says it is wrong, so do wil i take this answer and put it into another equation? or is my math wrong?
boomer77 said:
vf^2= vi^2 + 2ad
Solve for vi, of course! Try first solving for vi^2, then taking the square root.
i did do that and my answer came up as 3.55 (rounded) but my problem set is still saying it's wrong. where is my error?
vf^2=vi^2+2(-9.8)(-16.01)
(5vi)^2=0+313.8
25(vi^2)=313.8
313.8/25= 12.6
vi^2=12.6
vi=3.55
this equation that you wrote
17.8^2+3.6^2=(5x3.6)^2
what is it? I'm pretty new to physics (i started taking physics a this trimester at my high school) could you explain how to solve it?
(5vi)^2=0+313.8
25(vi^2)=313.8
313.8/25= 12.6
vi^2=12.6
vi=3.55
Your solution in your first post was correct. That's the one I want you to finish.
but isn't that 3.55 my answer?
No. You changed your equation, making it incorrect. Go back to your first post, or just see my first comment.
(5vi)^2=0+313.8
25(vi^2)=313.8
313.8/25= 12.6
vi^2=12.6
vi=3.55
You're so close :)
For questions like these you have to break everything into components, solve them, then put them all back together.
What I think you're doing wrong is breaking them into components, then using a mixture of components and other data within the wrong equation.
Here's a hint: Pythorgean Theorem
(I apologize for simply solving it before, hope this helps :))
so is this 3.55 one component?
As I've pointed out (several times), your initial solution was perfectly correct. (You might not realize that it was correct.) Why don't you finish it?
What allows you to combine perpendicular components is the fact that you are really combining their squares: V² = (Vx)² + (Vy)²
It would be if its magnitude was correct.
Think of it this way:
At the beginning, the ball's actual velocity has two components; an x valued velocity, and a y valued velocity.
At the end, the ball's actual velocity is composed of two parts just like in the beginning.
Think Pythagorean Theorem.
ohh i get it
my problem will be 3.55^2+x^2=5x^2!
then solve for x!
  • · Replies 22 ·
  • · Replies 21 ·
