Baryon density of the universe at recombination epoch
The baryon density of the universe at the recombination epoch (z=1200) can be calculated by multiplying the present baryon density by the cube of the expansion factor, which is 1200^3. The current baryon density is approximately 0.034 nanojoules per cubic meter, representing about 4% of the critical density of 0.85 nanojoules per cubic meter. For a rough estimate, using the formula 1200^3 * 0.034 nJ/m³ yields a density of approximately 6.5 x 10-19 kilograms per cubic meter or 0.059 joules per cubic meter.
  • Understanding of cosmological redshift (z) and its implications
  • Basic knowledge of baryonic matter and critical density
  • Familiarity with units of energy density (joules per cubic meter)
  • Proficiency in using scientific calculators for exponential calculations
  • Research the concept of cosmological expansion and its effects on density calculations
  • Learn about the critical density of the universe and its significance in cosmology
  • Explore baryonic matter and its role in the universe's structure
  • Investigate the use of calculators for astrophysical computations, particularly in cosmology
Astronomers, physicists, and students interested in cosmology, particularly those studying the early universe and baryon density calculations.
2203312
Hi
I am just looking for the formula to calculate the baryon density of the universe at the recombination epoch.
Is it a case of adding the average density of matter + radiation? but this does not take into account the recombination epoch (z=1200).
I do not have a background in physics (that is why I am here)
Space news on Phys.org
2203312 said:
Hi
Just for convenience let's say you want the baryon density at z=1199, so that z+1 = 1200.
That means that distances have expanded by a factor of 1200 since that time, and volumes have expanded by the cube, that is by the factor 12003
That means whatever the density is now, to find the density then you multiply by 12003
So your problem is simply to find the PRESENT baryon density.
In what form, in what units, do you want to know the density? As a number of particles per cubic meter? Or as kilograms of rest mass per cubic meter? Or as the energy equivalent of mass of the baryonic matter, in joules per cubic meter?
And how accurate do you want it?
If you want a rough estimate in joules per cubic meter that is easy. Today the critical density is 0.85 nanojoule per m3, and it is estimated that baryonic matter is about 4% of critical. So today the density if about 0.034 nJ per m3
Then you must simply multiply by 12003
The google calculator would help here. Put this in the box and press return"
1200^3*.034 nJ/m^3/c^2
It will give something like 6.5 x 10-19 kilogram per m3
If you don't insist on kilograms, and joules are OK you can say
1200^3*.034 nJ/m^3
and it will say 0.059 joule per cubic meter.
Many thanks for that
  • · Replies 27 ·
  • · Replies 26 ·
