Calculating Rotational Kinetic Energy and Instantaneous Rate of Change
The problem involves calculating the rotational kinetic energy of a hoop and determining the instantaneous rate of change of that kinetic energy when a tangential force is applied. The subject area is rotational dynamics, specifically focusing on the concepts of rotational kinetic energy and torque.
  • Mixed
  • Participants discuss the formula for rotational kinetic energy and the moment of inertia for a hoop. There is uncertainty regarding the effect of the applied force on the kinetic energy and how to approach the second part of the problem. Some participants explore the relationship between torque and angular acceleration, while others question the correct application of work done in relation to torque.
Participants are actively engaging with the problem, exploring different approaches to calculate the instantaneous rate of change of kinetic energy. There is a mix of attempts to clarify the role of torque and the application of relevant equations. Some guidance has been offered regarding the connection between torque and angular velocity, but no consensus has been reached on the final calculations.
There is confusion regarding the correct interpretation of the moment of inertia for the hoop and how to apply the force in the context of the problem. Participants are also navigating the implications of constant torque and its effect on the change in kinetic energy.
tachu101
A hoop of mass 1kg and radius 2m is rotating about its center with an angular speed of 3rad/sec. A force of 10N is applied tangentially at the rim.
a. The rotational kinetic energy of the hoop is?
b. The instantaneous rate at which the kinetic energy is changing is?
KE= 1/2Iw^2
For the first part I can find I= MR^2 for a hoop, so I= (1)(2^2) so I=4. So KE= 1/2Iw^2 = (1/2)(4)(3^2)= 18. What do I do with the extra 10N applied (do I just add it in or does it not factor into the rotational kinetic energy?) I don't know what equation to use for the second part.
KE= 1/2Iw^2
Hi tachu101! :smile:
KE is geometric … it only depends on the motion, not on what's causing it. :wink:
So you only need the 10N for the second part …
and for that, what equation do you know that connects force and rotation? :smile:
For the second part would I use torque=Ia which would then be torque/I=a? Would that be (10)(2)/((1)(2^2))= 5 rad/sec^2 does that help me?
(have an omega: ω and an alpha: α and a delta: ∆ :wink:)
tachu101 said:
For the second part would I use torque=Ia which would then be torque/I=a? Would that be (10)(2)/((1)(2^2))= 5 rad/sec^2 …
Yup! :smile:
That gives you dω/dt, from which you could find dKE/dt.
But there's a more direct way …
remember, ∆KE = ∆(work done) …
so what is the equation for work done by a torque ? :wink:
W= torque* [tex]\Delta[/tex][tex]\Theta[/tex] which would then be (10)(2)*(3)= 60J ? And how would I get dKe/dt from dW/dt
uh … W= torque*∆θ, where ∆θ is the total change in angle, is correct :smile:
but 3 is not the total change in angle, it's only the rate-of-change of angle, dθ/dt …
you need dW/dt = d(torque*θ)/dt :wink:
hmmm... am I missing an equation because I am not sure how to find the d(torque*θ)/dt? Also, given that I found 5 rad/sec^2 how could I use that to find a change in KE?
The torque here is constant, so d(torque*θ)/dt = torque * dθ/dt = torque * ω.
(you could use the dω/dt = 5 if you differentiate 1/2 Iω2
but it's more direct if you use the work done method)
So is (10)(2)*(3)= 60J Correct?
This would be easier to understand if you wrote it out in full …
but it's not joules anyway, is it?
Does the instantaneous change in KE equal torque * ω? Is torque (10)*(2)=20?
Instantaneous rate of change in KE equal torque * ω.
And yes, torque (10)*(2)=20. :smile:
In summary...
I think that part a is 9J because I think it is (1/2)(I)(w^2)= 9
Part b is then torque*W which is then (10)(2)*(3)= 60
tachu101 said:
In summary...
I thought you got 18J for a? :confused:
Yup, b is 60. :smile:
I looked back and I think I missed a 1/2 in part a. It should be (1/2)((1/2)(1)(2^2))(3^2)= 9 I think I missed the 1/2 in the I value.
What 1/2? :confused: … it's a hoop, not a disc.
Going to bed now … :zzz:
  • · Replies 21 ·
  • · Replies 33 ·
  • · Replies 58 ·
